[snappyHexMesh] How to visualize the castellated mesh?
Like Tree1Likes
  • 1 Post By roth
Old   August 25, 2011, 05:15
Default How to visualize the castellated mesh?
Hikachu is on a distinguished road
I am totally beginner on snappyHexMesh, and my problem is pretty simple : how can I visualize the castellated mesh.
I did :
>snappyHexMesh
>paraFoam
but all I have is a big block (I am supposed to have the guy on a motor-bike).
Thanks for your help!
Hikachu is offline   Reply With Quote
Old   August 25, 2011, 06:13
tobijingles is on a distinguished road
Hi Hikachu!
There are many ways to visualize the mesh in paraview. You can select how to display the geometry (surface, outline, wireframe, ...) in a dropdown menu. I think the best way to start is reading the user guide for paraview on http://www.paraview.org/paraview/hel...mentation.html
There you can learn how to do slices, cutouts and so on to visualize everything.
Good luck!
Tobias
tobijingles is offline   Reply With Quote
Old   August 25, 2011, 06:45
Elvis
elvis will become famous soon enough
Advanced Paraview Tutorial @ Sixth OpenFOAM workshop, Dave DeMarle, Kitware, Inc.
http://www.openfoamworkshop.org/6th_...rle_slides.pdf
elvis is offline   Reply With Quote
Old   August 26, 2011, 09:54
Default Zeroing in on the "castellated" part of the question
Michael Roth
roth is on a distinguished road
Btw, if you're interested in looking at the castellated i.e. block-like structure of your mesh, a good filter in Paraview is "Extract Cells By Region" e.g. attachment below.
Steps:
  1. Load in your foam case (uncheck the "Decompose Polyhedra" if the option is available)
  2. Apply the Extract Cells By Region filter, checking the boxes for "Extract only intersected" and "Extract intersected".
I'm using Paraview 3.10.1, with the native openfoam reader, but the steps should be similar, regardless. The case used in the attachment is the flange tutorial.
Mike
wernsen likes this.
roth is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] Disturbance in the mesh after the addition of layers Dorian1504 OpenFOAM Meshing & Mesh Conversion 0 June 13, 2017 02:27
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 05:03
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
