[snappyHexMesh] grow rate of cells
Old   October 3, 2011, 04:09
Default grow rate of cells
Alexander
Svensson is on a distinguished road
Send a message via Skype™ to Svensson
In cfd computations grow rate of cells should be about 1.1-1.5 near a wall. But in all examples from tutorials aspect ratio of conectings edges is 2. How can I change it?
Thanks in advance!
Svensson is offline   Reply With Quote
Old   October 4, 2011, 08:21
Tomislav Maric
tomislav_maric is on a distinguished road
Thanks in advance!
Edit this kind of line in the "const/blockMeshDict" file:
hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1)
there you will see that the mesh grading is defined alongside edges of every block. There are more information on this in the User Guide:
http://www.openfoam.com/docs/user/bl...#x25-1420005.3
Tomislav
tomislav_maric is offline   Reply With Quote
Old   October 4, 2011, 09:47
Alexander
I'm asking about another problem.. I use snappyHexMesh and would like to have 'grow rate' from the body with any coefficient (in my case 1.3).
Is it possible in sHM?
Old   October 4, 2011, 10:28
Tomislav Maric
I remember it being possible, but I can't remember how to use it... I did set this up a while ago, but if I remember correctly, it was only the refinement increase for the bulk of the mesh in defined regions. For instance, there was a distance vector of some kind (if I remember correctly), and for every different distance from a patch, a different refinement level is prescribed.
Tomislav
Epyc 7551 vs 6850K; Ansys Mechanical Bench Duke711 Hardware 24 March 26, 2020 10:16
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
shear rate and strain rate Lilly FLUENT 1 August 29, 2014 00:46
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
