[blockMesh] Automated transitions in blockMesh?
Old   January 10, 2012, 16:51
Default Automated transitions in blockMesh?
the.drizzle is on a distinguished road
Hiya!
Owing to the limited memory on this machine, I am being forced to use more elegant meshing techniques than what I would like to do. Probably a good thing in the long run, but for now a bit of a pain.
What I'm wondering for the moment is if there is a way of automatically defining some sort of transition from a fine mesh to a coarse one that allows one to build a transition region that is then compatible with snappyHexMesh? The attached image illustrates (in a very invalid way, I know) roughly what I am trying to go from and to.
I can see how to do this manually, but I'm thinking that this must be a feature somewhere...
the.drizzle is offline   Reply With Quote
Old   January 10, 2012, 19:30
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Originally Posted by the.drizzle View Post
Hiya!
I don't know about fully automatic. Off the top of my thick skull, I would try writing a script (in your favorite scripting language) that would create a series of adjacent refinement boxes with gradually increasing (or decreasing) refinement levels, then copy and paste the result into your snappyHexMeshDict. Unless I am misreading what you want to do (which is entirely possible).
mturcios777 is offline   Reply With Quote
Old   January 10, 2012, 19:37
Nah, not misreading it at all, but that's (more or less) the process I'm trying to avoid if at all possible. In other words, what you have described is what I would call a manual refinement.
Old   January 10, 2012, 19:46
Marco A. Turcios
There might be something in pyFoam, but what is pyFoam other than a scripting language wrapped around a programming language (its the "Inception" of CFD programs [not sure if you are familiar with that film]). You could make it so that at least you can set the number of regions and extent as input parameters. Almost makes me want to do it myself. ALMOST.
That said, save any scripts you make for the future. Every now and again I find myself wishing I hadn't thrown away a snippet of code/script/utility because I thought I would "never use it again". Now I keep a sort of "junk drawer" full of that kind of stuff that at best gives me exactly what I need, and at the very least inspires my though process.
Old   January 12, 2012, 23:45
mergePatchPairs is the key! Except it doesn't seem to deal with corners very well...
I've attached an un-commented version of my my blockMeshDict file so you can see what I'm talking about. Basically, if I comment out some of the patch pairs in such a manner that no merging is happening on adjacent faces, it works fine. The end result is useless of course, but the fact remains that the merging works.
So, what I'm wondering at this point is if there is something I can do to get faces to merge around corners like I'm trying to do here? I'm thinking I'm probably going to have to take a different strategy altogether, but we'll see...
Thanks in advance for any help!
|  \\    /   O peration     | Version:  2.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1e-6;
vertices
        (-250   -125    -1150)  // 0
        (-78    -125    -1150)
        (78     -125    -1150)
        (1900   -125    -1150)
        (-250   5.2875  -1150)  // 4
        (-78    5.2875  -1150)
        (78     5.2875  -1150)
        (1900   5.2875  -1150)
        (-250   1243.3425       -1150)  // 8
        (-78    1243.3425       -1150)
        (78     1243.3425       -1150)
        (1900   1243.3425       -1150)
        (-250   1375    -1150)  // 12
        (-78    1375    -1150)
        (78     1375    -1150)
        (1900   1375    -1150)
        (-250   -125    -50)    // 16
        (-78    -125    -50)
        (78     -125    -50)
        (1900   -125    -50)
        (-250   5.2875  -50)    // 20
        (-78    5.2875  -50)
        (78     5.2875  -50)
        (1900   5.2875  -50)
        (-250   1243.3425       -50)    // 24
        (-78    1243.3425       -50)
        (78     1243.3425       -50)
        (1900   1243.3425       -50)
        (-250   1375    -50)    // 28
        (-78    1375    -50)
        (78     1375    -50)
        (1900   1375    -50)
        (-250   -125    158.5)  // 32
        (-78    -125    158.5)
        (78     -125    158.5)
        (1900   -125    158.5)
        (-250   5.2875  158.5)  // 36
        (-78    5.2875  158.5)
        (78     5.2875  158.5)
        (1900   5.2875  158.5)
        (-250   1243.3425       158.5)  // 40
        (-78    1243.3425       158.5)
        (78     1243.3425       158.5)
        (1900   1243.3425       158.5)
        (-250   1375    158.5)  // 44
        (-78    1375    158.5)
        (78     1375    158.5)
        (1900   1375    158.5)
//      Need an extra set of points for the finer block
        (-78    5.2875  -50)            //48 = 21
        (78     5.2875  -50)            //49 = 22
        (-78    1243.3425       -50)    //50 = 25
        (78     1243.3425       -50)    //51 = 26
        (-78    5.2875  158.5)          //52 = 37
        (78     5.2875  158.5)          //53 = 38
        (-78    1243.3425       158.5)  //54 = 41
        (78     1243.3425       158.5)  //55 = 42
blocks
//  Thick layer
        hex (0 1 5 4 16 17 21 20) (3 2 18) simpleGrading (1 1 1)
        hex (1 2 6 5 17 18 22 21) (3 2 18) simpleGrading (1 1 1)
        hex (2 3 7 6 18 19 23 22) (28 2 18) simpleGrading (1 1 1)
        hex (4 5 9 8 20 21 25 24) (3 20 18) simpleGrading (1 1 1)
        hex (5 6 10 9 21 22 26 25) (3 20 18) simpleGrading (1 1 1)
        hex (6 7 11 10 22 23 27 26) (28 20 18) simpleGrading (1 1 1)
        hex (8 9 13 12 24 25 29 28) (3 2 18) simpleGrading (1 1 1)
        hex (9 10 14 13 25 26 30 29) (3 2 18) simpleGrading (1 1 1)
        hex (10 11 15 14 26 27 31 30) (28 2 18) simpleGrading (1 1 1)
//  Thin layer
        hex (16 17 21 20 32 33 37 36) (3 2 3) simpleGrading (1 1 1)
        hex (17 18 22 21 33 34 38 37) (3 2 3) simpleGrading (1 1 1)
        hex (18 19 23 22 34 35 39 38) (28 2 3) simpleGrading (1 1 1)
        hex (20 21 25 24 36 37 41 40) (3 20 3) simpleGrading (1 1 1)
        hex (48 49 51 50 52 53 55 54) (10 78 13) simpleGrading (1 1 1)  // Fine block, merging required
        hex (22 23 27 26 38 39 43 42) (28 20 3) simpleGrading (1 1 1)
        hex (24 25 29 28 40 41 45 44) (3 2 3) simpleGrading (1 1 1)
        hex (25 26 30 29 41 42 46 45) (3 2 3) simpleGrading (1 1 1)
        hex (26 27 31 30 42 43 47 46) (28 2 3) simpleGrading (1 1 1)
edges
boundary
patches
        patch top_master
                (22 21 25 26)
        patch top_slave
                (48 49 51 50)
        patch front_master
                (37 41 25 21)
        patch front_slave
                (54 52 48 50)
        patch back_master
                (42 38 22 26)
        patch back_slave
                (53 55 51 49)
        patch left_master
                (38 37 21 22)
        patch left_slave
                (52 53 49 48)
        patch right_master
                (41 42 26 25)
        patch right_slave
                (55 54 50 51)
mergePatchPairs
        (top_master top_slave)
        (front_master front_slave)
        (back_master back_slave)
        (left_master left_slave)
        (right_master right_slave)
Old   January 20, 2012, 17:42
OK, I still would like to know why the above patching problem fails in general, but I saw after posting that the concept I posted above would fail for two primary reasons:
- snappyHexMesh requires hexahedron elements only, and the above merging has to break this constraint.
- snappyHexMesh (more or less) requires that all the cells in the initial mesh have an aspect ratio somewhere around unity, which again will the above merging technique will break.
For future reference, what has worked is that I have had to break up the initial parts into sub-parts in a manner that corresponds to where the mesh refinement levels are required, with the interfaces defined as patch regions. One can then use snappyHexMesh to mesh all of the "oddball" shapes one at a time, and then glue the parts back together via mergeMeshs and stitchMesh.
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh colinB OpenFOAM Meshing & Mesh Conversion 8 January 22, 2012 10:32
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
