[snappyHexMesh] Some problems about using snappyHexMesh
Prev Previous Post   Next Post Next
Old   April 9, 2012, 04:27
Unhappy Some problems about using snappyHexMesh
xiaoweii
xiaow_g is on a distinguished road
Hello everybody,
I just started to use snappyHexMesh and tried to test some existed applications in OpenFOAM-2.1.0 to be familiar with the use of snappyHexMesh.
The directory is "./tutorials/incompressible/simpleFoam/turbineSiting/". I run some commands according to "Allrun". Firstly "blockMesh", then "cp system/decomposeParDict-nonPar system/decomposeParDict", then "decomposePar", then "cp system/decomposeParDict-par system/decomposeParDict", then "mpirun -np 2 snappyHexMesh -parallel -overwrite". The execution didn't finish and got stuck as below:
| \\ / O peration | Version: 2.1.0-snappy |
| \\/ M anipulation | |
Build : 2.1.0-bd7367f93311
Exec : snappyHexMesh
Date : Apr 09 2012
Time : 16:16:32
Host : "ln0"
PID : 24934
Case : /vol6/home/test605/OpenFOAM/OpenFOAM-2.1.0-snappy/tutorials/incompressible/simpleFoam/turbineSiting-bak
nProcs : 1
Create time
Create mesh for time = 0
Read mesh in = 0.23 s
Overall mesh bounding box : (581321 4785370 930) (582290 4786240 1500)
Relative tolerance : 1e-06
Absolute matching distance : 0.00142153473401
Reading refinement surfaces.
Read refinement surfaces in = 0.11 s
Reading refinement shells.
Refinement level 6 for all cells inside windTurbine1
Refinement level 6 for all cells inside windTurbine2
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0 s
Reading features.
Read features in = 0 s
Determining initial surface intersections
Edge intersection testing:
Number of edges : 56100
Number of edges to retest : 56100
Obviously the execution didn't finish. Does anyone know how to solve this problem? Thank you!
xiaow_g is offline   Reply With Quote
snappyhexmesh parallel
[snappyHexMesh] Problems with coarse/unsnapped cells in snappyHexMesh scareneb OpenFOAM Meshing & Mesh Conversion 2 August 13, 2014 07:13
[snappyHexMesh] snappyHexMesh problems 1.5->1.6 grtabor OpenFOAM Meshing & Mesh Conversion 5 May 18, 2012 03:00
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
[snappyHexMesh] SnappyhexMesh and Symmetryplane bastil OpenFOAM Meshing & Mesh Conversion 10 October 7, 2008 17:07
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
