Solid Mechanics Solvers added to OpenFOAM Extend |
September 11, 2012, 12:06 |
Philip Cardiff
Rep Power: 34 |
Hi All,
I have been meaning to do this for a while and I have finally got around to it. I have assembled the finite volume solid mechanics solvers that have been developed by my research group under the guidance of Prof. Alojz Ivanković, University College Dublin. A large number of people have contributed to the development of the solvers: Aleksandar Karac, Zeljko Tukovic, Hrvoje Jasak, Philip Cardiff, Declan Carolan, Michael Leonard and Valentine Kanyanta. The included solid mechanics solvers employ the finite volume method (not finite elements) to numerically approximate the displacements and stresses in solid bodies undergoing deformation. The included solvers are suitable for small strain, small strain with large rotations, large strain, cohesive zones, plasticity, thermal- elasticity, visco-elasticity, gravity forces, fluid-structure interactions, multi-material analyses and contact stress analysis. A number of custom boundary conditions with full non-orthogonal correction are including time-varying displacements and tractions, fixed rotations, and fixed displacements with zero shear stress. The solvers have been added as a feature branch to OpenFOAM-1.6-ext. To download, get OpenFOAM-1.6-ext using git: Code:
git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext Code:
git checkout -b feature/solidMechanics remotes/origin/feature/solidMechanics Hopefully some of you will find this useful and maybe some of you will be converted from finite elements Have fun. Best regards, Philip Last edited by bigphil; September 13, 2012 at 05:05. Reason: fixing the git command to download the branch again (changed sollidMechanics to feature/solidMechanics in local branch) |
September 12, 2012, 02:06 |
I have download the OF-1.6-ext successfully but it did not contaion the solidMechanics also when I run this code : git checkout -b solidMechanics origin/solidMechanics the following error is shown
fatal: Not a git repository (or any of the parent directories): .git if what folder this code should be executed ? Please help me to download the solidMechanics solver Best Regards |
September 12, 2012, 04:25 |
Philip Cardiff
Rep Power: 34 |
Hi Mechy,
sorry the command to get the solidMechanics branch is (this command is executed in the OpenFOAM-1.6-ext directory): Code:
git checkout -b feature/solidMechanics remotes/origin/feature/solidMechanics Philip Last edited by bigphil; September 13, 2012 at 05:06. Reason: changed the git command |
February 13, 2013, 16:19 |
#4 | |
Philip Cardiff
Rep Power: 34 |
That's good to hear that you find them useful. You are right, nOuterCorr is not that clear. In my defence I did not develop this solver But I can change it the next time I update the code. Best regards, Philip PS As the OpenFOAM-1.6-ext git is currently down, I have put a ".tgz" of the solidMechanics solvers here (4.7 MB). I normally put the solidMechanics directory in $FOAM_SOLVERS. |
June 9, 2013, 07:54 |
Philip Cardiff
Rep Power: 34 |
Dear all,
I have recently compiled the solidMechanics code on OpenFOAM-2.2.0. I had to disable a couple of features (it should be possible to get them working with a bit of time), but at least you can try out the code if you only have access to official OpenFOAM. A ".tgz" of the solidMechanics code for OpenFOAM-2.2.0 can be downloaded here. Extract the solidMechanics_OpenFOAM-2.2.0.tgz file to the $FOAM_SOLVERS directory and then compile using the include Allwmake script. Note, the disabled features are:
Best regards, Philip |
August 25, 2013, 20:09 |
Hi Dr. Cardiff,
I attempted to download OpenFOAM 1.6-ext using the command git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext However I received the error fatal: The remote end hung up unexpectedly. I ended up downloading the version using git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext However, I was unable to checkout the solid solvers branch using git checkout -b feature/solidMechanics remotes/origin/feature/solidMechanicsI ended up downloading the solidMechanics.tgz from one of the earlier posts. I would like to know whether I should be extracting all the contents (including tutorials) to the solvers folder that is located within the applications directory. Thanks & Regards |
August 26, 2013, 03:01 |
Christian Lucas
Hi
have a look at http://sourceforge.net/p/openfoam-ex...i/master/tree/ git path to master branch is: git clone git://git.code.sf.net/p/openfoam-extend/OpenFOAM-1.6-ext openfoam-extend-OpenFOAM-1.6-ext Christian |
August 26, 2013, 09:07 |
Hi Chris,
Thanks for the git path to the master branch. However, I was unable to checkout the solidMechanics feature and ended up downloading the solidMechanics.tgz from one of the earlier posts. I needed confirmation that the contents (including tutorials) have to be extracted to the solvers folder located within the applications directory. Thanks & Regards |
August 26, 2013, 09:20 |
#9 | |
Philip Cardiff
Rep Power: 34 |
Apologies, the solidMechanics branch is no longer a git branch as it has been merged into the nextRelease branch getting ready for the nextRelease. One can see all the remote branches using this command: Code:
git remote show origin Code:
git checkout -b nextRelease origin/nextRelease Philip |
September 14, 2013, 15:21 |
#10 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
And adapted it to be built on OpenFOAM 2.1.x and 2.0.x... well, no so much as adapting, simply regressed the changes you had made for OpenFOAM 2.2.0 Further modifications are explained on the updated "README.md" file . Note: I have not tested any of the tutorials on any of the mentioned OpenFOAM versions Best regards, Bruno
November 24, 2013, 07:36 |
#11 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
In an attempt to make it easier to keep track of announcements regarding this very precious solidMechanics tool-kit, I've moved all of the posts that were support related to this thread: https://www.cfd-online.com/Forums/op...am-extend.htmlSo please, ask support questions there In addition, I've created a quick page at openfoamwiki.net for making it easier to keep the latest information on the location of the solidMechanics tool-kit: http://openfoamwiki.net/index.php/Co...solidMechanics Anyone, please feel free to extend that page with more information, such as tutorials and ideas!! Best regards, Bruno Last edited by wyldckat; December 30, 2017 at 20:24. Reason: updated link to support thread |
May 1, 2014, 12:11 |
#12 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
The repository https://github.com/wyldckat/solidMechanics has a new branch for OpenFOAM 2.3.x. Direct link to said branch, named OF23x: https://github.com/wyldckat/solidMechanics/tree/OF23x - installation instructions can be found on that page. edit: I forgot to mention that I have not checked if there have been any fixes made on foam-extend 3.0 that should be ported to this repository. Best regards, Bruno Last edited by wyldckat; May 1, 2014 at 12:27. Reason: see "edit:" and fixed typo |
August 19, 2014, 05:25 |
help thermal expansion + contact
#13 |
Manuele Aufiero
Dear all,
I am trying to use the elasticThermalSolidFoam solver of version 3.1 in presence of contact stresses. Is it possible? I modified the tutorial slidingFrictionBall. Temperature is solved correctly, but I got this error at the definition of Ueqn if master and slave patches are defined like in the original tutorial: Code:
Solving for U --> FOAM FATAL ERROR: request for volVectorField U_0 from objectRegistry region0 failed available objects of type volVectorField are 5 ( U UPrevIter aitkenDelta grad((((threeK*rho)*alpha)*(T-T0))) divSigmaExp ) From function objectRegistry::lookupObject<Type>(const word&) const in file /7gpr/aufiero/foam/foam-extend-3.1/src/foam/lnInclude/objectRegistryTemplates.C at line 139. FOAM aborting Aborted (core dumped) Any help will be appreciated. Thank you very much. Manu
Manuele Aufiero |
May 26, 2015, 15:19 |
#14 |
Philip Cardiff
Rep Power: 34 |
For those interested in Fluid-Solid-Interactions (FSI): In case you were not aware, the new FSI framework (currently located in foam-extend-3.1/extend-bazaar) supersedes the icoFsiElasticNonLinULSolidFoam FSI solver within the solidMechanics toolbox. This framework was presented at the OpenFOAM Workshop 2014 in Zagreb: abstract and slides. The major improvement with regard to FSI coupling is the implementation of the IQN-ILS algorithm. Also, the plugin approach used for the solid and fluid solvers should allow easier extension to other fluid/solid models e.g. multi-phase, compressible, plasticity, etc. Best, Philip |
September 5, 2015, 19:01 |
#15 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
Instructions for properly building the Fluid-Structure Interaction toolkit with foam-extend 3.1 is now available here: http://openfoamwiki.net/index.php/Ex...oam-extend_3.1 I've also git'ified the source code: https://github.com/wyldckat/FluidStructureInteraction Best regards, Bruno
February 3, 2016, 16:24 |
#16 |
Hiran Wijesinghe
I want to model the vibrational modes of a micro-scale structure. I basically want to specify a transient boundary condition and be able to see the normal modes. Is solidMechanics the tool I should look for? Thanks |
February 10, 2016, 05:00 |
#17 | |
Philip Cardiff
Rep Power: 34 |
There is currently no implementation for calculating eigenvalues/eigenvectors/vibration models although it should be possible. Simulating using a geometrically nonlinear (aka large strain) approach could work depending on the problem. Philip |
April 30, 2016, 22:56 |
keyword nonLinear is undefined in dictionary
#18 |
I have installed the Solidmechanics, but when I run the cases in the tutorials, a fatal error "keyword nonLinear is undefined in dictionary " rises. Can you tell me how to solve this error? Thanks!
The following are the log file /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : elasticPlasticSolidFoam Date : May 01 2016 Time : 10:28:04 Host : "ThinkPad-T430u" PID : 7474 Case : /home/sheavon/OpenFOAM/sheavon-2.3.0/run/solidMechanics/tutorials/elasticPlasticSolidFoam/timeVaryingPlasticPlateHole nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field DU --> FOAM FATAL IO ERROR: keyword nonLinear is undefined in dictionary "/home/sheavon/OpenFOAM/sheavon-2.3.0/run/solidMechanics/tutorials/elasticPlasticSolidFoam/timeVaryingPlasticPlateHole/0/DU.boundaryField.right" file: /home/sheavon/OpenFOAM/sheavon-2.3.0/run/solidMechanics/tutorials/elasticPlasticSolidFoam/timeVaryingPlasticPlateHole/0/DU.boundaryField.right from line 31 to line 33. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 437. FOAM exiting ************************************************** ************************************************* DU.boundaryField.right right { type timeVaryingSolidTraction; outOfBounds clamp; fileName "$FOAM_CASE/constant/timeVsRightTraction"; } |
May 3, 2016, 12:19 |
#19 |
Philip Cardiff
Rep Power: 34 |
The following should fix it:
right { type timeVaryingSolidTraction; outOfBounds clamp; fileName "$FOAM_CASE/constant/timeVsRightTraction"; nonLinear off; value uniform (0 0 0); } |
June 14, 2016, 14:04 |
#20 |
Ricardo Ferreira
Rep Power: 11 |
Hi Guys.
I'm trying to reproduce the HronTurekFsi3 tutorial from extend-bazaar. I installed those toolkits based on instructions from HTML Code:
https://openfoamwiki.net/index.php/Extend-bazaar/Toolkits/Fluid-structure_interaction Code:
--> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 124 could not load libhronTurekReport.so: cannot open shared object file: No such file or directory Ricardo. |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/openfoam-news-announcements-other/106881-solid-mechanics-solvers-added-openfoam-extend.html
Posted By | For | Type | Date | |
Solid Mechanics Solvers added to OpenFOAM Extend - Page 4 -- CFD Online Discussion Forums | This thread | Refback | September 16, 2013 10:14 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 17:55 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
OpenFOAM Version 1.4 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | April 11, 2007 18:56 |
Testing of OpenFOAM 1.4alpha Commenced | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | January 16, 2007 09:41 |
Testing of OpenFOAM 1.3alpha Commenced | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | February 7, 2006 07:31 |
