Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
customized ubuntu14.04LTS
Like Tree1Likes
  • 1 Post By Astrodan
Old   March 9, 2016, 05:04
Default customized ubuntu14.04LTS
Nima Samkhaniani
nimasam is on a distinguished road
Dear foamer
OpenFOAM3.0.1 is released sometimes ago, meanwhile i see some newbies struggle in installation of OpenFOAM, therefore i customized Ubuntu14.04LTS to include OpenFOAM in it.
you can download the the modified Ubuntu iso file from here.
to configure openfoam after linux installation
Open the .bashrc file in the user’s home directory in an editor, e.g. by typing in a terminal window (note the dot)
  1. gedit ~/.bashrc
  2. At the bottom of that file, add the following line and save the file source /opt/openfoam30/etc/bashrc
Best Regards
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   March 10, 2016, 06:41
Timm Severin
Astrodan is on a distinguished road
If you edit /etc/skel/.bashrc newly created profiles should automatically contain the new line, so that no further configuration is necessary.
Apart from that I'd personally assume an Ubuntu Iso is a bit overkill, a .deb Package would have been sufficient, but then again I always compile it myself, so what would I know..
nimasam likes this.
PhD Student at the Institute of Biochemical Engineering at TU München
Modelling of fluid dynamics in open photobioreactors.
System:
OpenFOAM 2.3.x, 64bit, 8 Core Xeon Workstation
Astrodan is offline   Reply With Quote
openfoam3.0, ubuntu14.04lts
Compiling the customized source code problem cfdmatteo Fluent UDF and Scheme Programming 1 July 9, 2016 09:49
Problems running customized solver for diffusion mmkr825 OpenFOAM Running, Solving & CFD 1 August 30, 2012 14:01
customized sonicFoam for adaptive mesh refinement - how to define mass flow BCs? shockley OpenFOAM 1 December 13, 2010 04:04
Customized User Field Function - Vector hannow STAR-CCM+ 1 December 10, 2009 07:25
Customized solver to run in parallel hsieh OpenFOAM Running, Solving & CFD 3 September 21, 2006 04:59
