Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
Solver that combines VOF with DFM and manual
Like Tree5Likes
  • 5 Post By JonW
Old   August 2, 2021, 14:18
Default Solver that combines VOF with DFM and manual
Jon Elvar Wallevik
JonW will become famous soon enough
Hi everyone
In the beginning of last year, I finalized a project about the stability and segregation of fresh concrete during flow/casting at jobsite. For the CFD part of the project, I had to write a solver that combines the Volume of Fluid Method (VOF) with the Drift Flux Model/Method (DFM). The code is for high viscous non-Newtonian fluid and thus does not include turbulence. Since I was also in the full panic of changing job when finished with the project, I didn’t contemplate on announcing the solver part at the time. But here it is anyway.
The manual is perhaps the best part. It goes in step-by-step manner into DFM (chapter 2) and VOF (chapter 3) separately and mixing of the two (chapter 4), so if the solver is not of interest, you might like the manual. It also addresses the relevant rheology of suspensions in chapter 5 as well as theories for segregation (i.e. slip between phases) in chapter 6. List of source code and compilation info are in the appendix. If you are going to use the solver, please read (and understand) the manual first.
Manual:
https://github.com/JonWallevik/vvpfFoamManual
(you can also find it in researchgate.net)
Videos:
https://www.youtube.com/watch?v=7vzAfyCSv1c
https://www.youtube.com/watch?v=Y0Du5cc-Dvk
https://www.youtube.com/watch?v=DzXHVauA6gk
Source code:
Case example:
https://github.com/JonWallevik/vvpfFoamCaseExample1
Good luck,...
Jon
JonW is offline   Reply With Quote
dfm, drift flux model, vof, volume of fluid
