[OpenFOAM] Animation always starts from zero
Old   November 13, 2013, 01:27
Default Animation always starts from zero
Martin Goddard
McFly is on a distinguished road
I have the following two issues with paraFoam running on a cluster with OF 2.1.1.
I want to save out images of each timestep for an iso-surface. However, when I run the "save animation" sequence after about 60 images it starts saving images of the background without the iso-surface. So it works fine initially, then stuffs up.
The second issue occurs when I try to restart the animation sequence from the missing images. I use the animation view to select the sequence: start time, end time, no of frames. But when I run this sequence it ALWAYS starts playing from timestep 0, with weird intervals up to the end time.
My current work around is to remove the directories it has already output correctly and then just run it again - but this is silly.
Does anyone have an answer to these issues?
Thanks,
Marty
McFly is offline   Reply With Quote
Old   November 13, 2013, 20:21
Martin Goddard
The second issue seems to have fixed itself. Logging in last night and today the animation panel works correctly.
However the first issue remains - Paraview starts saving images without surface content after about 50 timesteps. Any ideas?
No errors are reported.
Marty
Old   November 14, 2013, 03:28
startingWithCFD is on a distinguished road
Hey there! I also had problems in the past with paraview animations (freezing after some frame, probably due to memory limitations). Two remedies may be to only load what you need (for example I only loaded the outside patch) and to play around with the settings (I think the "Cache geometry" setting made a big difference in my case). I hope this helps.
startingWithCFD is offline   Reply With Quote
Old   November 14, 2013, 12:39
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hello Martin,
Are you sure that the iso-surface still exists at the timesteps where it dissapears from the simulation? Just trying to eliminate all possible sources of error, and I've had that happen where I haven't adjusted my range properly.
mturcios777 is offline   Reply With Quote
Old   November 18, 2013, 19:19
Martin Goddard
Thanks for the replies.
The surface exists for all timesteps. As I was in a hurry I ran the animation for 50 timesteps several times (only 300 timesteps total) to produce the required frames.
I will have to try the 'cache geometry' option - memory usage is probably the culprit given the size of the dataset.
animation, parafoam, paraview
Solution Animation Error Jacob_Bing FLUENT 2 July 28, 2022 08:10
Animation Sweep Plane not displaying correctly u2berggeist FLUENT 1 August 26, 2018 20:51
Animation of Fluent transient data saisanthoshm88 FLUENT 2 December 18, 2012 09:51
Animation query..newbie qn derick FLUENT 2 December 9, 2005 09:45
Animation in Tecplot ryoga Tecplot 0 February 18, 2002 11:19
