Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Paraview: Cell data and Point Data?
Like Tree10Likes
  • 1 Post By vitor
  • 6 Post By alberto
  • 3 Post By sushant
Old   July 9, 2010, 09:47
Default Paraview: Cell data and Point Data?
Vitor Braga
vitor is on a distinguished road
I'm trying to calculate the average velocity in the outlet of a pipe.
I use the filter Integrate Variables, but I dont know how to interpret the data, I mean, what is the difference between the values of velocity in the Cell Data and Point Data? They are quite different.
If I wish to calculate the average velocity in the outlet, which should I choose?
Just to make sure, Paraview integrates in the area, so all I have to do is divide this value by the area of the pipe, and this will give me the average velocity, right?
Thank you.
BR,
Vitor.
Gang Wang likes this.
vitor is offline   Reply With Quote
Old   July 9, 2010, 12:46
Nima Samkhaniani
nimasam is on a distinguished road
hi friend
as i guess cell data is the value of cell center but point data are the value of cell points for example in hex mesh we have 8 data for points of a cell but just one data for cell center
nimasam is offline   Reply With Quote
Old   July 10, 2010, 05:30
Alberto Passalacqua
Originally Posted by vitor View Post
The cell values are the raw data saved by the solver, while the point values are interpolated on the cell points.
If with outlet you mean a boundary condition, the most appropriate way is to average in the code, using the face values on the patch.
Best,
Alberto Passalacqua
Old   December 23, 2010, 00:09
Default Utilities
sushant's Avatar
sushant is on a distinguished road
Take a look at the following utilities:
patchAverage Calculates the average of the specified field over the specified patch
patchIntegrate Calculates the integral of the specified field over the specified patch
If all you want to do is calculate average velocity magnitude over the outlet patch. You don't need to open up ParaView to do that. Note that velocity is a volVectorField and only volScalarFields can be averaged, so use
foamCalc mag U
to find and write magU if you want to work with velocity. Then
patchAverage magU outlet
From OpenFOAM-Wiki:
The builtin cell-to-point filter works like a Cell Data to Point Data filter in ParaView in that it just takes the average of cell values connected to a point. The difference is that the builtin filter takes boundary patch values into account. The filter is faster but less accurate than the volPoint interpolator in paraFoam, which further does inverse distance weighting of cell values. The cell-to-point filter is still computationally demanding thus can be turned off by unchecking "Create cell-to-point filtered data" on the reader panel.
( ∫∫ ψ dA ) / ( ∫∫ dA )
= ( ∫∫ ψ dA ) / A
= average of ψ over A
So yes.
( Sorry to bump an old thread but hope this is helpful )
Last edited by sushant; December 23, 2010 at 01:24. Reason: didn't notice OP specifically asked about ParaView
sushant is offline   Reply With Quote
Old   May 15, 2015, 17:56
james wilson
jameswilson620 is on a distinguished road
I found this relevant thread but didn't find any specific information for my case.
I'm looking to access cell point values associated with a field. I'm using a hex mesh and am doing interface reconstruction. I require access to the point values since using cell values alone for calculating the interface normal only considers 6 adjacent cells (2 in x, y and z) for 3D and is less accurate and results in large parasitic currents.
Any advice regarding RUNTIME utilities, functions etc. would be beneficial.
See also: http://www.cfd-online.com/Forums/ope...ue-access.html
James
jameswilson620 is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 20:06
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
paraview - cell data or point data on plot over line bye bye my blue OpenFOAM 0 December 13, 2016 06:07
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
