Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to use python script in paraFoam?
Old   October 12, 2015, 04:34
Default How to use python script in paraFoam?
pan
Thomas pan is on a distinguished road
I am using the Postprocessing for Turbomachinery,I download the code from:http://sourceforge.net/projects/turbopost/,but i don't know how to use them in paraFoam.
I try the turbofilter.py in the turbevtk.And I use the ProgrammableFilter,the script is:
import sys
sys.path.insert(0 ,"/home/username/python/vtk/")
import turbofilter as filter
## Input format default value is openfoam
## Set input format to numeca
filter.setInputFormat("numeca")
## omega default value is 0.0
filter.omega = 2*filter.math.pi*28160.0/60.0
## Calculate only Cm, Cr and Cu
filter.setTrue(["Cm", "Cr", "Cu","Ma", "MaRel"])
## All variables were calculated
# filter.setAllTrue()
## run calculation
filter.run(self)
But I get the error:
File "<string>", line 2
if not file:///home/pjc/OpenFOAM/pjc-1.6-ext/turbopost-turbovtk/src/turbofilter.py
SyntaxError: invalid syntax
Traceback (most recent call last):
File "<string>", line 26, in <module>
File "<string>", line 16, in RequestData
File "/home/pjc/OpenFOAM/pjc-1.6-ext/turbopost-turbovtk/src/turbofilter.py", line 744, in run
turbofilter(curInput, curOutput)
File "/home/pjc/OpenFOAM/pjc-1.6-ext/turbopost-turbovtk/src/turbofilter.py", line 521, in turbofilter
Cr.InsertNextValue((input_loc.GetPoint(i)[:3][0]*input_loc.GetPointData().GetVectors(absolutVeloci tyXYZ).GetTuple3(i)[0]+input_loc.GetPoint(i)[:3][1]*input_loc.GetPointData().GetVectors(absolutVeloci tyXYZ).GetTuple3(i)[1])/radius)
AttributeError: 'NoneType' object has no attribute 'GetTuple3'
I have also try the python shell in paraview,it doesn't work.
Who can tell me the step of using python script in paraview?thanks.
Thomas pan is offline   Reply With Quote
filter, parafoam, paraview, python script, turbo
[OpenFOAM] Using python script for automatic post processing of openFoam vPaquet ParaView 12 December 16, 2021 03:30
python script to create geometry for salome, and then mesh 6863523 Mesh Generation & Pre-Processing 4 March 18, 2017 09:00
How to use python script in paraFoam? Thomas pan OpenFOAM Post-Processing 0 October 13, 2015 21:29
[OpenFOAM] using the python shell in paraFoam colinB ParaView 14 September 14, 2015 09:04
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 09:36
