Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] ParaView 33 Python Shell error
Old   August 19, 2008, 15:05
Default ParaView 33 Python Shell error
Michael Schoenberg
mschoenberg is on a distinguished road
I've just built ParaView 3.3 after enabling Python in the CMakeLists.txt file. It seemed to build fine, but when I attempt to run the python shell, it brings up the shell with this message:
>>> from paraview import servermanager
Traceback (most recent call last):
File "<string>", line 1, in ?
File "/home/michael/OLDOF/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Icc/Ut ilities/VTKPythonWrapping/paraview/servermanager.py", line 43, in ?
import re, os, new, exceptions, sys, vtk
File "/home/michael/OLDOF/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Icc/Ut ilities/VTKPythonWrapping/paraview/vtk.py", line 4, in ?
from libvtkCommonPython import *
ImportError: No module named libvtkCommonPython
I've looked around and the libvtkCommonPython.so file exists in both the /ParaView3.3-cvs/platforms/linux64Icc/bin directory and the /ParaView3.3-cvs/platforms/linux64Icc/lib directory. I've updated my LD_LIBRARY_PATH to include the location of these libraries, but this has failed to solve the problem.
Any help is greatly appreciated.
mschoenberg is offline   Reply With Quote
Old   August 19, 2008, 17:32
Default No. Python wants to find the .
Assistant Moderator
Bernhard Gschaider
No. Python wants to find the .so's as modules (and for those it looks in PYTHONPATH). So in ~/OpenFOAM/OpenFOAM-1.5/etc/apps/paraview3/bashrc after the lines that set the PYTHONPATH to the .py-files:
if [ "$PYTHONPATH" ]; then
export PYTHONPATH=$PYTHONPATH:$ParaView_DIR/Utilities/VTKPythonWrapping
else
export PYTHONPATH=$ParaView_DIR/Utilities/VTKPythonWrapping
fi
add this line
export PYTHONPATH=$ParaView_DIR/lib/paraview-3.3/:$PYTHONPATH
restart the shell and everything should be fine (it was for me). If you're using tcsh something similar should be done.
If it works for you, could you please file a report in the Bugs-section so that it will be fixed in the next Release?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 20, 2008, 10:42
Default Thanks a bunch, this solved th
Michael Schoenberg
Thanks a bunch, this solved the problem. I'll file a bug report.
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
