Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Streamlines in 3d geometry
Old   January 23, 2008, 10:03
Default Streamlines in 3d geometry
Manuel Larenas Aravena
mlarenas is on a distinguished road
I'm just beginning with OpenFoam and I've been working on a 3d mesh. As it says in the UserGuide, you have to extract the Internal Mesh to plot the streamlines... but I need to plot them through the entire 3d geometry! is there a way to perform this?
I would really appreciate any help
Manuel
mlarenas is offline   Reply With Quote
Old   June 2, 2008, 18:34
Default Hi I can plot streamlines i
Alexandre Pereira
alexandrepereira is on a distinguished road
Hi
I can plot streamlines in an extracted mesh in ParaFoam ( Paraview 2.4.4 ). I am using OpenFOAM 1.4.1, the issue is that some of the streamlines break in a nonphysical fashion... they just get interrupted, it happens with large cases 2.5 M cells,
i am running OF in Ubuntu 7.10 w/ 2GB memory and an ATI Radeon Mobility x2300...
Is there any form of fixing this ( besides the obvious one of running a smaller case... :-) ) ?
It it some kind of bug already fixed in Paraview 3.x, or is it OS specific...?
Thanks in advance
Alex
alexandrepereira is offline   Reply With Quote
Old   June 2, 2008, 20:01
Default Hi Alexandre, Does your mesh
Takuya OSHIMA
7islands is on a distinguished road
Hi Alexandre,
Does your mesh contain polyhedral (incl. split-hex) cells? If that's the case try foamToVTK instead of directly reading your case with paraFoam. foamToVTK does a better job in decomposing polyhedral cells than paraFoam's on-the-fly decomposer, which largely affects the behavior of the streamline filter.
Takuya
7islands is offline   Reply With Quote
Old   June 3, 2008, 10:00
Default Hi Oshima Takuya, Thanks fo
Alexandre Pereira
Hi Oshima Takuya,
Thanks for your fast answer. I can do that allrignt :
foamToVTK . mycase -ascii -allPatches -fields "(U p k epsilon phi)" -time 3.2
as an example, but the issue is that i do not know how to manipulate the VTK database, extract its features, etc...
In paraFoam environment i would simply extract the internal mesh, extract one or several patches ( an airplane surface for instance ) colour that patch by pressure. apply an isosurface operator to that patch so as to explicit the isopressure lines over that surface ( in a healthy design they should be as orthogonal to the direction of flow as possible, any departure from that condition will mean that there may be conditions for pressure gradient reversal... bad news...), and apply the streamline operator to the internal mesh...
... just as easy as that... with a VTK database... well ... :-(
How do i extract a patch ? ( a car or an airplane surface... )... ?
Can i apply operators as simply as do it in an OpenFOAM database...?
Somehow the "extract parts" feature is not active in the "filter" scroll down menu...
... wy whole querying ability gets compromised...
...How do i do it...?
Alex
Old   June 3, 2008, 19:53
Default Hi Alex, You could try to run
Takuya OSHIMA
Hi Alex,
You could try to run foamToVTK again with -allPatches removed from your command line, and read *.vtk files for each patch created under VTK/<patchname> directory.
Takuya
Old   June 4, 2008, 17:38
Default Hi OSHIMA Takuya Thanks onc
Alexandre Pereira
Hi OSHIMA Takuya
Thanks once more,
I did as you told and no way... i cannot extract inner boundaries in my cfd domain...
It may be possible, but i do not know how to do it with VTK format...
Anyway, i built streamlines from my Vtk database... changed its visibility so that only the streamlines would be visible, and tha same thing happens... lots of streamlines broken for no apparent reason...
Happens in a vtk database in paraview 2.4.4 and paraview 3.2.1.
On the other hand, if i choose an Ensight data export and open it in Ensight 8.2.2 Gold, the streamlines are there allright... not randomly broken...
My problem is that my trial license of EnSight is almost expiring... and i am running short of options... :
MayaVi won't open VTK databases in unstructured format like paraview does... if it wasn't for the cranked streamlines... :-(
Thanks anyway...
Regards
Alex
Old   June 6, 2008, 10:47
Default Hi Again Oshima. I have sol
Alexandre Pereira
Hi Again Oshima.
I have solved my difficulty in VTK manipulation...
The patches are all located in another folder inside the main VTK database folder... from there i can select whichever patch i need to open, and post it in Paraview... no need to extract features like in a Foam database...
BTW, do you happen to know when will Paraview 2.4.4 be superseeded by paraview 3.x as a default OpenFOAM viewer...?
Best regards
Alex
Old   June 6, 2008, 11:08
Default Hi, @3.x migration: I (or all
Takuya OSHIMA
@3.x migration: I (or all the community?) believe we don't have to wait so long before it happens [1].
[1] http://www.opencfd.co.uk/openfoam/version1.5beta.html
Takuya
Old   June 9, 2008, 21:06
Default Hi Oshima, One more questio
Alexandre Pereira
Hi Oshima,
One more question... is there any way to import EnSight format into Paraview without the *%&"#)? "core dump"...?
Should i import it in "Little Endian" or "Big Endian" Format...?
As far i I can recall, Paraview 2.4.4. won't allow it,... Paraview 3.2.1 won't either...
is there some kind of "trick" to be used in foamToEnsight? or it is just the way things are, not being able to use Paraview with EnSight Format...?
Best regards
Alex
Old   June 9, 2008, 21:51
Default Hi Alex, I have almost no e
Takuya OSHIMA
Hi Alex,
I have almost no experience with foamToEnsight so I guess you could ask Mark in another thread [1], especially if you are interested in its polyhedra handling.
[1]http://www.cfd-online.com/OpenFOAM_D...tml?1212995919
Takuya
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 03:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 13:49
Geometry for Confined Circular Jet Greatness FLUENT 0 October 1, 2013 05:04
Export geometry file from ansys mechanical browns6 Structural Mechanics 0 August 27, 2013 16:19
2D geometry to 3D geometry Sgonzalezg ANSYS Meshing & Geometry 11 April 8, 2011 11:02
