Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Fluent to Paraview
Like Tree1Likes
  • 1 Post By Nick
Old   April 14, 2008, 11:41
Default Fluent to Paraview
Nick
I have managed to export from Fluent to Paraview v3.2.1 , using the ensight case format and I can view my results ok,
but can anybody tell whether I can access the zone information from fluent i.e walls and inlets etc of my model. is this possible in Paraview? or has something gone wrong in the translation?
I want to display contours on a complex 3d surface.
cheers
Nick
Old   April 14, 2008, 17:24
Default re: Fluent to Paraview
Charles
Use the filter "Extract Datasets". Here the 3.* versions of Paraview are inferior to the later 2.* versions like 2.6, which kept the names of the surfaces.
Old   April 15, 2008, 03:55
Nick
aha, thats worked thankyou,
yes its a shame it has not picked up the names.
is their a way to rename the Groups and blocks in paraview, I can't seem to see anything obvious.
Old   April 15, 2008, 05:34
Charles
Not that I know of. But rolling back to 2.6 is not really a big hardship, it is pretty capable, and in some respects (like the named zones) easier to use.
Old   April 16, 2008, 11:14
federico
Hi, I was trying to do the same, namely export fluent files to paraview using the ensight format, but i failed, simply because the files exported by fluent have the extension .encas .geo .vel .scl, while the files read by paraview should have extensions .case or .sos i tryed to read these files anyway but it didn't work. can you tell me how should i proceed? thanks a lot, Federico
Old   April 16, 2008, 11:17
Nick
just rename your *.encas file to *.case , paraview will read this file (this file is just a reference for all the others) and automatically read in the scalars and geometry. make sure you set paraview to the little endian option.
bestucan likes this.
Old   April 16, 2008, 11:25
federico
thanks a lot!
CFX vs. FLUENT turbo CFX 4 April 13, 2021 08:08
export Fluent CFX results to paraview? phsieh2005 CFX 1 June 24, 2015 05:16
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
Fluent to Paraview Lilly FLUENT 2 September 19, 2012 12:40
From FLUENT data to Paraview bart weisser FLUENT 1 July 16, 2010 04:41
