Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] AVI MPEG problem in PV 24
Old   March 11, 2008, 08:39
Default AVI MPEG problem in PV 24
kar
Kārlis Repsons
kar is on a distinguished road
have you experienced this problem: when create a movie from solution data with many steps, PV launches some app "paraview-real". That app eats whole memory and swap and computer is hanged (busy)?
I had to restart it violently. I'm pretty sure, that simulation with 100x100 cells can't take so much mem if does properly!
Also, is there some way to make those avi-s like this: create view state in PV, save it; launch video making app (through ssh for example) and gives state file as argument. Also time interval could be set?
Regards,
Kārlis
kar is offline   Reply With Quote
Old   March 11, 2008, 09:50
Default I think there is a bug in that
Assistant Moderator
Bernhard Gschaider
I think there is a bug in that paraview version. Turn off the buttons that say "Cache mesh" in the Import Panel and "Cache Geometry" in the Animation panel. One of them should be labled "Turn on memory leak" (Am not sure which one)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 27, 2008, 08:44
Default Bernhard, you just made me la
kar
Kārlis Repsons
Bernhard,
you just made me laugh Thanks! I'll try it.
Kārlis
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 19:41
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
