[OpenFOAM] How to plot a contour of a zcoordinate on a surface |
August 30, 2007, 15:59 |
Sung-Eun Kim
Rep Power: 17 |
I'm trying to visualize surface elevation of an water/air interface using interFOAM result. First I made an iso-surface of volume-fraction (gamma = 0.5). Nect, I was trying to plot filled contour of z-coordinate on the iso--surface. I could not do it, because z-coordinate was not available in the data paraFoam read in.
Can someone help? |
August 30, 2007, 16:45 |
Hmm... I guess what you say sh
Rep Power: 18 |
Hmm... I guess what you say should be done easily in TecPlot... of course if you have TecPlot
August 30, 2007, 16:53 |
I suppose so. My question was
Sung-Eun Kim
Rep Power: 17 |
I suppose so. My question was how to do it using paraFoam. How do you export OpenFOAM data in Tecplot format?
August 30, 2007, 16:58 |
foamToTecPlot tool:
http://ww
Rep Power: 18 |
foamToTecPlot tool:
http://www.cfd-online.com/OpenFOAM_D...ges/1/424.html Then if you want transfer ascii data to binary, use tec2bin tool under the same topic. Hope that helps. Good luck! |
y+ contour plot through flow domain | Katha | CFX | 5 | July 20, 2017 07:38 |
How to Contour plot for omega_z ?? | snehal | OpenFOAM | 3 | March 11, 2017 05:41 |
How ot plot pressure over an object surface? | vilius | STAR-CCM+ | 2 | March 25, 2015 15:50 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
[OpenFOAM] Contour Plot with Paraview | jet | ParaView | 0 | August 26, 2010 10:30 |
