Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] ParaFoam Error
Old   June 27, 2007, 22:51
Default ParaFoam Error
Jonatas
jblucca is on a distinguished road
Im running the binaries provided at OpenFOAM's site on a Ubuntu box.
OpenFOAM works OK but when I try to run paraFoam on the interFoam/damBreakFine tutorial directory, i got these error messages:
$ paraFoam
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
ParaView error: InitializeTcl failed
Tk_Init error: this isn't a Tk applicationcouldn't connect to display ":0.0"
Im trying to run in on my localhost X.
DISPLAY enviroment variable is set to :0.0
Does anybody knows what is wrong?
Can anybody help me please?
Thanks
Jonatas
jblucca is offline   Reply With Quote
Old   June 28, 2007, 02:37
Default This error usually appears whe
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
This error usually appears when you run remotely through an ssh connection, and want to print on the localhost X server ... but it seems this is not the case here.
Try the following command on the localhost:
xhost +
This will enable everybody to print on your screen, so be carefull if you belong to an untrusted network.
Dragos
dmoroian is offline   Reply With Quote
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
