Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] pvpython, using ProbeLocation
Old   May 8, 2015, 12:30
Default pvpython, using ProbeLocation
dmaz is on a distinguished road
Hi I'm trying to access to the probe data of a point in a simulation using pvpython.
I run the pitzDaily tutorial in OpenFoam and in Paraview I can see the probe values using the command "probe location", specifying the point coordinate.
I'm setting the pvpython script in this way:
from paraview.simple import *
pitzDaily_foam = OpenFOAMReader( FileName='/home/pyt/pitzDaily/pitzDaily.foam' )
AnimationScene1 = GetAnimationScene()
AnimationScene1.EndTime = 817.0
AnimationScene1.PlayMode = 'Snap To TimeSteps'
pitzDaily_foam.TimestepValues.GetData()
pitzDaily_foam.CellArrays = ['U', 'epsilon', 'k', 'nuTilda', 'nut', 'p']
pitzDaily_foam.LagrangianArrays = []
pitzDaily_foam.MeshRegions = ['internalMesh']
pitzDaily_foam.PointArrays = []
ProbeLocation1 = ProbeLocation( ProbeType="Fixed Radius Point Source" )
ProbeLocation1.ProbeType.Center = [0.2, 0.0, 0.0]
From there, I'm not able to extract the information using the command ProbeLocation, what can I do?
Thanks in advance,
Dmaz
dmaz is offline   Reply With Quote
[General] Paraview Shell and PVPython Mismatch subhasis ParaView 1 June 1, 2018 06:32
[OpenFOAM] Correctly loading my casefiles via pvpython karma15 ParaView 3 August 18, 2016 09:44
[General] Export spreadsheet from pvpython wgan ParaView 0 June 10, 2016 15:53
[General] pvpython can't find numpy seanread ParaView 0 April 4, 2016 21:40
[OpenFOAM] matlab call a pvpython script, ecountering error dalianwei ParaView 0 July 11, 2015 12:09
