Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Velocity not visible
Old   January 3, 2024, 07:19
Default Velocity not visible
Laura
lv0907 is on a distinguished road
After running my model in Openfoam, I want to process it in Paraview. I don't see the velocity field in my model. Does someone perhaps now what is wrong with it? Is it because I need to do an extra step in Paraview? Or is it because my model doesn't provide the velocity as an output?
I have made my controlDict as follows:
| \\ / O peration | Version: v2006 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application interFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 0.003;
deltaT 0.003;
writeControl adjustableRunTime;
writeInterval 0.003;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 1;
maxAlphaCo 1;
maxDeltaT 0.1;
functions
turbulenceFields1
// Mandatory entries (unmodifiable)
type turbulenceFields;
libs (fieldFunctionObjects);
// Mandatory entries (runtime modifiable)
// Either field or fields entries
fields (k R);
lv0907 is offline   Reply With Quote
Old   January 9, 2024, 02:51
M
AtoHM is on a distinguished road
In general, Paraview can only show fields that were written out by the solver. So a first step would be to check in the time folders created, the presence of a file "U". What probably happens is, that you specify the writeInterval with 0.003 which is also the endTime. The timestep you visualize in PV is 0.0004.
The fact that you see this timestep at all, I think is, because of the functions { turbulenceFields1 ... } in your controlDict. Without giving a writeControl there, it will print out these values at each iteration.
So a solution would be to lower the global writeInterval so it prints U in intermediate steps too. Keep in mind that this prints not only U in intermediate steps but also alpha, rho, ... . You can also use writeCompression on; in the controlDict and still see everything in Paraview, which saves you some storage space.
AtoHM is offline   Reply With Quote
Unexpected velocity profiles for pipe flow with elbows K-al-Eps-o Main CFD Forum 20 March 21, 2023 14:04
wrong velocity contour of rotating propeller - Fluent calv FLUENT 1 September 6, 2018 11:48
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation mykkujinu2201 Main CFD Forum 1 August 12, 2017 13:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
