Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] foamToVTK and paraFoam show different results
Old   October 28, 2010, 10:45
Default foamToVTK and paraFoam show different results
akidess's Avatar
Anton Kidess
I've been using foamToVTK to post-process my data, and recently started playing around with Tecplot (using foamToTecplot360). To my surprise I was getting different velocity vectors in Tecplot and Paraview (3.8.1). I then tested paraFoam with paraview's integrated foam-reader (not the opencfd plugin), and the results were the same as using Tecplot (see below).
The geometry I'm plotting is an axisymmetric wedge, and the problems appear at the symmetry axis. Can anyone explain what foamToVTK is doing different than the native paraview reader?
Old   October 28, 2010, 20:48
Takuya OSHIMA
7islands is on a distinguished road
Hi Anton,
If the left edge is the axi-symmetric wedge, in this case I guess formToVTK is correct. Regarding the internal reader in ParaView the boundary value handling has been an issue as has been reported by another post. It's definitely in my to-do list but still take time as it is non-trivial.
Takuya
7islands is offline   Reply With Quote
Old   October 29, 2010, 05:36
akidess's Avatar
Anton Kidess
Hi Takuya, thanks for your prompt response, and I appreciate you working on this.
The post you linked does look like exactly the same issue. But you are in good company, as the tecplot converter and also the sample utility don't seem to handle the wedge tip correctly. I'm in contact with the Tecplot support and hope to be able to resolve the issues there as well.
- Anton
foamToVTK will have a different values?! And the fvScheme questions. wenxu OpenFOAM Running, Solving & CFD 20 August 4, 2020 07:51
[OpenFOAM] Visualization problem on ParaFoam Rider ParaView 10 June 27, 2016 10:19
I can not see anything in paraFoam Please help anmartin OpenFOAM Installation 2 February 11, 2010 04:37
Kubuntu 8.10: paraFoam differences between 32 and 64 bit. Can you help me? Xwang OpenFOAM Installation 0 June 28, 2009 07:26
[OpenFOAM] FoamToVTK Animation with Paraview 3 podallaire ParaView 5 October 9, 2007 07:26
