[OpenFOAM] Calculating Lift and Drag in Paraview (paraFoam) |
January 9, 2018, 06:54 |
coeff of Lift and Drag in paraview
#21 |
Adarsh Singh
Is it possible to calculate the cl and cd on the surface generated by immersed boundary method, in paraview? I have pressure value all over the surface. |
January 31, 2018, 01:10 |
#22 | |
mohammad amin adibipoor
Rep Power: 8 |
Thanks for the tip Only one question What do you mean ba "yourDensity"? Body or water? |
January 31, 2018, 03:00 |
#23 |
The fluid, obviously, as you are looking for the forces exerted by it and using it's pressure...
August 6, 2018, 01:33 |
#24 |
Chayanit Nigaltia
Rep Power: 8 |
Are you not considering velocity in coefficients calculation?
August 6, 2018, 07:51 |
#25 |
Chayanit Nigaltia:
the formulas I gave give force/moment values. If you want a specific coefficient you have to compute it from there. |
March 31, 2019, 10:47 |
#26 | |
ok
Rep Power: 7 |
Can you help? |
August 22, 2019, 06:26 |
how to calculate drag force
#27 |
Rajesh Dattatray Ingale
hi,
i getting drag coefficient 0.4066 and the drag force is 0.3411 N but by manual calculation i m getting 0.06N please help me on this. |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
calculating lift and drag coefficients _ running in parallel | Mike_star | OpenFOAM Programming & Development | 1 | April 4, 2016 11:16 |
[OpenFOAM] Display lift and Drag in paraview | SamerAli | ParaView | 1 | May 16, 2013 12:51 |
calculating drag and lift in fluent | morteza08 | FLUENT | 4 | December 13, 2012 15:34 |
