Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Functions on internal patches
Like Tree1Likes
  • 1 Post By gl_sb
Prev Previous Post   Next Post Next
Old   August 22, 2012, 10:24
Default Functions on internal patches
gl_sb is on a distinguished road
I have a problem with OF and I would be very glad, if someone can help me!
Inside my fluid domain I have an "internal patch" on which I want to get some Information about the flow field and the mesh. The "internal patch" was already meshed in Ansa so after the export from Ansa to OF 2.0 I get a faceZones entry in the polyMesh-folder.
Now I need the following values of every single face of the "internal patch":
- Velocity
- Area
- Coordinates of the face centres
First I tried to get these values through the following function definition in the controlDict:
Values_internal_patch
type faceSource;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
outputControl timeStep;
outputInterval 1;
log true;
valueOutput true;
source faceZone;
sourceName internal_patch;
operation sum;
fields
phi
U
I did't get the U values because for faceZones it is not possible to access VolFields. For this we need a patch as source. So I continued convert the faceZone "internal_patch" into two patches with cyclic boundary conditions via the createBaffle command:
createBaffles internal_patch '(internal_patch_1 internal_patch2)'
I got the following result in my boundary file:
internal_patch_1
type cyclic;
nFaces 1779;
startFace 6094853;
matchTolerance 0.0001;
neighbourPatch internal_patch_2;
internal_patch_2
type cyclic;
nFaces 1779;
startFace 6096632;
neighbourPatch internal_patch_1;
In all the variable file in the 0 folder I added the following lines:
internal_patch_1
type cyclic;
internal_patch_2
type cyclic;
And defined a new function within my controlDict:
Values_internal_patch_1
type faceSource;
enabled true;
outputInterval 1;
log true;
valueOutput true;
source patch;
sourceName internal_patch_1;
operation sum;
fields
phi
U
Now I get phi and U, but only 889 values are printed to the output file and not 1779. Note that the patch consits of 1779 single faces (1414 Tias and 365 Quads). When I use the function in connection with for example the "Inlet" boundary, everything is fine and I get the same number of entries in the output files for every variable like faces forming the "Inlet".
Has anybody an idea? Thanks for every hint
samiam1000 likes this.
gl_sb is offline   Reply With Quote
[mesh manipulation] Remove internal patch(es) SD@TUB OpenFOAM Meshing & Mesh Conversion 17 June 20, 2019 13:05
How to handle internal patches for p,T,U monsoon OpenFOAM 16 March 22, 2013 15:00
Internal patches openFoam Aerospace OpenFOAM 1 November 6, 2010 05:30
[Commercial meshers] Internal patches with fluentMeshToFoam sega OpenFOAM Meshing & Mesh Conversion 12 October 29, 2009 08:11
[snappyHexMesh] internal faces between patches created with snappyHexMesh romant OpenFOAM Meshing & Mesh Conversion 0 August 17, 2009 08:40
