May 15, 2013, 15:07 |
forces calculation on wigley case
Vincenzo
Rep Power: 13 |
Hello everyone
I am doing simulations on a boat for an internship university and I arrived at the point of having calcolarmi forces. I read about all threads by adding the relevant command lines in controlDict but the results I get are unacceptable: too small and above all never go to convergence. the flow has a speed of 3m / s. how can I fix? command lines I add are these: functions { forces { type forces; functionObjectLibs ("libforces.so"); patches ("hull_wall"); pName p; Uname U; rhoName rho; rhoInf 1000.0; COFR (0 0 0) OutputControl timestep; outputInterval 1; log true; magUInf 3.0; } } the name of the patches is that correct? if not, where can I see that right? the library to which you refer is correct for OpenFOAM 2.2.0 (this is the version I use)? please help me. I have a sense of urgency! |
[OpenFOAM] Forces Calculation | m_f | OpenFOAM Post-Processing | 13 | April 12, 2018 19:16 |
Forces on wall in unsteady case | sondinho | FLUENT | 4 | December 8, 2012 07:55 |
forces in interFoam | Svensson | OpenFOAM Post-Processing | 2 | May 9, 2012 13:31 |
i need a case file for erosion calculation | Mysara Mohyaldinn | FLUENT | 0 | September 24, 2008 22:32 |
Wigley hull test case | giovanni ieria | Main CFD Forum | 0 | November 22, 1999 11:30 |
