January 13, 2014, 12:19 |
#21 |
Rep Power: 14 |
Hi wyldckat,
Thank you very much for your help. For example, in the following tutorial: Code:
OpenFOAM/openfoammaofnepo-2.1.1/run/tutorials/combustion/XiFoam/les/pitzDaily3D Code:
yPlusLESWCompressible -time 0.0002 -compressible Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : yPlusLESWCompressible -time 0.0002 -compressible Date : Jan 13 2014 Time : 10:08:33 Host : "stokes" PID : 353 Case : /users/of/OpenFOAM/openfoammaofnepo-2.1.1/run/tutorials/combustion/XiFoam/les/pitzDaily3D nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0.0002 Time = 0.0002 Calculating wall distance Writing wall distance to field y Reading field U Selecting thermodynamics package hhuMixtureThermo<homogeneousMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>> --> FOAM FATAL ERROR: Unknown basicThermo type hhuMixtureThermo<homogeneousMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>> Valid basicThermo types are: 26 ( ePsiThermo<pureMixture<constTransport<specieThermo<eConstThermo<perfectGas>>>>> ePsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> ePsiThermo<pureMixture<sutherlandTransport<specieThermo<eConstThermo<perfectGas>>>>> ePsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>> ePsiThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>> hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> hPsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>> hPsiThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>> hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<incompressible>>>>> hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<isobaricPerfectGas>>>>> hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> hRhoThermo<pureMixture<icoPoly3ThermoPhysics>> hRhoThermo<pureMixture<icoPoly8ThermoPhysics>> hRhoThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<isobaricPerfectGas>>>>> hRhoThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>> hRhoThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<isobaricPerfectGas>>>>> hRhoThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>> hsPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> hsPsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>> hsPsiThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>> hsRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<isobaricPerfectGas>>>>> hsRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> hsRhoThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<isobaricPerfectGas>>>>> hsRhoThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>> hsRhoThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<isobaricPerfectGas>>>>> hsRhoThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>> ) From function basicThermo::New(const fvMesh&) in file basicThermo/basicThermoNew.C at line 60. FOAM exiting Last edited by openfoammaofnepo; January 29, 2014 at 10:49. |
January 13, 2014, 17:52 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi openfoammaofnepo,
Thanks for the detailed description! It a lot easier to reproduce the same error! I've updated the branch "of21x" on the repository. Follow the download and installation instructions once again from the updated page: https://github.com/wyldckat/yPlusLES...ble/tree/of21x The new utility is named "yPlusLESWCompressibleNCombustion", so try it instead of the utility "yPlusLESWCompressible". Best regards, Bruno
January 16, 2014, 15:04 |
#23 |
Rep Power: 14 |
Thank you so much, Bruno.
That can be used now. But it is specific for the thermophysical options. Thank you. |
January 22, 2014, 15:09 |
#24 | |
Rep Power: 14 |
Dear wyldckat,
Thank you so much for your help. In the utilities you upload recently: yPlusLESWCompressibleNCombustion In the following source files: Code:
yPlusLESWCompressibleNCombustion Code:
yPlus.boundaryField()[patchi] = d[patchi] *sqrt ( muEff.boundaryField()[patchi] *mag(U.boundaryField()[patchi].snGrad()) *rho.boundaryField()[patchi] ) /muLam.boundaryField()[patchi]; Thank you so much. Quote:
January 22, 2014, 18:20 |
#25 | |
Bruno Santos
Rep Power: 128 |
So my question is: what is the reasoning you've followed for making that suggestion? In addition: are you using the "-compressible" option for running the application? Best regards, Bruno
January 22, 2014, 19:09 |
#26 |
Rep Power: 14 |
Thanks. I just followed the definition of yPlus like Code:
http://www.cfd-online.com/Wiki/Dimensionless_wall_distance_(y_plus) I use the option '-compressible' and it is OK. Thank you for your sharing. |
January 26, 2014, 09:00 |
#27 |
Bruno Santos
Rep Power: 128 |
OK, let's see how I can manage LaTeX equations here on the forum... based on these wiki pages:
In contrast, the equation present on the utility is this (if I'm not mistaken): Yes, you are correct!!! It's missing a inside the square root! Feel free to report this at the official bug tracker: http://www.openfoam.org/bugs/ - since this problem is present in the original code of the function object "yPlusLES". If you don't want to report this yourself, I can report this for you. Best regards, Bruno
January 26, 2014, 10:21 |
#28 |
Rep Power: 14 |
Dear Bruno,
Thank you for your help. What do you mean by "original code"? We do not have the original compressible LES yPlus. In the incompressible version, the equation should be correct. If it is convenient for you, please help us to report this to them. I think we need to correct. Although the values of yPlus will not have big difference, however, conceptually it is not correct without rho. Thank you for your help. Best, op**po |
January 26, 2014, 10:31 |
#29 | |
Bruno Santos
Rep Power: 128 |
It's available as a function object, as explained here http://www.openfoam.org/version2.2.0...processing.php - and I quote: Quote:
OK, I'll report this in a minute and edit this post indicating the bug report. edit: Reported here: http://www.openfoam.org/mantisbt/view.php?id=1141 - I'll wait for them to fix the issue and then I'll propagate the fix to my repository. Best regards, Bruno
January 26, 2014, 10:35 |
#30 |
Rep Power: 14 |
OK, many thanks!
I always use OF211 and so I did not find that. Thank you for your help! Have a nice Sunday! |
January 26, 2014, 10:50 |
#31 |
Rep Power: 14 |
Besides, just for curiosity, how did you input the equations in the thread? ......simple questions for you.
January 26, 2014, 11:08 |
#32 | |
Bruno Santos
Rep Power: 128 |
There you'll find this thread: http://www.cfd-online.com/Forums/sit...ne-forums.html |
January 26, 2014, 11:12 |
#33 |
Rep Power: 14 |
Got it, many thanks!!
January 29, 2014, 10:53 |
#34 |
Rep Power: 14 |
Hello Bruno,
Any update from the bug report? Was it indeed a bug or just any other saying? Just for my knowledge. Thank you so much. |
January 30, 2014, 17:15 |
#35 | |
Bruno Santos
Rep Power: 128 |
Best regards, Bruno |
January 31, 2014, 23:27 |
#36 |
Bruno Santos
Rep Power: 128 |
I've done some more homework and prepared 2 test cases that solve pretty much the same simulation, but using compressible vs incompressible variants of the same solver, namely pimpleFoam vs rhoPimpleFoam. The cases are provided in the bug report and also in my repository. The conclusion is that I do believe that you are right in affirming that "rho" is missing inside the square root and these two test cases seem to prove that. Therefore, I've applied this fix to the source code in the utilities at my repository. Best regards, Bruno
February 1, 2014, 06:14 |
#37 |
Rep Power: 14 |
Thank you for your information, Bruno!
Have a nice day! |
February 1, 2014, 18:15 |
#38 |
Bruno Santos
Rep Power: 128 |
Well, the bug fix has finally been implemented in 2.2.x: http://www.openfoam.org/mantisbt/view.php?id=1141
The commit can be viewed here: https://github.com/OpenFOAM/OpenFOAM...17f4ec1bde1348 The strange detail is that Henry chose to implemented the division by "rho" in both occurrences of "mu", instead of using the single multiplication by "rho" inside the square root. There are two possibilities for this:
February 1, 2014, 18:59 |
#39 |
Rep Power: 14 |
Thank you, Bruno. I read their updated code of yPlusLES. At least from the the point of view of math, it is correct. I cannot say more in terms of numerical precision. Do they provide any awards for the bug reports? :-) :-)
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Natural Convection using Compressible Flow (chtMultiRegionFOAM) | msarkar | OpenFOAM | 2 | September 7, 2010 00:13 |
help with compressible flow BC's (need subsonic flow) | meangreen | Main CFD Forum | 5 | July 24, 2010 13:16 |
Compressible Fluid Flow in COMSOL Multiphysics | BBG | COMSOL | 1 | November 19, 2008 14:05 |
Solving unsteady compressible low speed flow | atit | Main CFD Forum | 8 | July 31, 2000 13:19 |
