Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
foam to VTK error
Old   June 5, 2013, 03:46
Default foam to VTK error
hhh
kunar
hhh is on a distinguished road
hai friends,
i am doing 2d naca0012 airfoil analysis for turbulent case using simplefoam for angle of attack 2. I try to convert results in VTK format,but i got error like this
file: /home/kum/freefoam-user-doc/tutorials/incompressible/simpleFoam/airfoil/2/0/nut::boundaryField::airfoil from line 37 to line 38.
From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
in file /build/buildd/freefoam-0.1.0+dfsg/obj-x86_64-linux-gnu/include/finiteVolume/../../../src/finiteVolume/fields/fvPatchFields/fvPatchField/newFvPatchField.C at line 110.
FOAM exiting
kindly guide me
hhh is offline   Reply With Quote
Old   June 8, 2013, 16:06
Retired Super Moderator
Bruno Santos
Greetings Kumar,
This isn't enough information to help you
Can you share the file "0/nut"?
Or can you post what is on the lines 37 and 38 of this file?
And just to confirm, did you run simpleFoam with success?
Best regards,
Bruno
PS: I moved your post to a new thread, since the error is different from the other thread.
Old   June 8, 2013, 23:36
hhh
kunar
Thanks wyldckat to coming forward to help me.
I successfully run simplefoam and got results for all, i am doing angle of attack of 0,2,4,6,8,10.but problem is to convert VTK format.please see my attached file.
Old   June 9, 2013, 05:43
Bruno Santos
Hi Kumar,
OK, the problem seems to be that foamToVTK does not recognise the boundary condition "nutSpalartAllmarasWallFunction".
If it were OpenFOAM instead of FreeFOAM, the following steps should work:
  1. Edit the file "system/controlDict".
  2. Add this line to it:
    libs ("libincompressibleRASModels.so");
  3. Save and close the file.
  4. Try foamToVTK once again.
You can these steps with FreeFOAM, but you might have to adjust the name of the library name.
Best regards,
Bruno
Old   June 10, 2013, 06:01
Default foam to VTK
hhh
kunar
Hai Bruno,
I unstall freefoam,because again its give the same error, so i install ubuntu 11.10 with openfoam 2.1. but I got this error during mesh conversation fluentMeshtoFoam,please tell me what i have to do?
"version to version i get confused,this is final one i install[ubuntu 11.10 with openfoam 2.1]"
toshiba@ubuntu:~/openfoam210/tutorials/incompressible/simpleFoam/airFoil2D$ fluentMeshToFoam naca0012.msh
fluentMeshToFoam: command not found
Old   June 10, 2013, 07:12
Bruno Santos
Hi Kumar,
Which exact OpenFOAM installation instructions did you follow?
Best regards,
Bruno
Old   June 10, 2013, 11:57
Default foamToVTK
hhh
kunar
Hi Bruno, i install ubuntu 11.10 with openfoam version 2.1.0
LINK: http://www.openfoam.org/archive/2.1....oad/ubuntu.php
Old   June 10, 2013, 13:21
Bruno Santos
Hi Kumar,
What does the file "~/.bashrc" have near the end of the file? Does it only have the following line?
source /opt/openfoam210/etc/bashrc
Or is there still any reference to FreeFOAM?
And what about the following command:
icoFoam -help
Does it show anything?
Best regards,
Bruno
Old   June 11, 2013, 02:04
Default foamToVTK
hhh
kunar
Thanks Bruno,that step i forgot to did. I run cavity,right now everything works fine.
For airfoil i got another error like this, i did any mistake please let me know
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.0-0bc225064152
Exec : fluentMeshToFoam naca0012.msh
Date : Jun 11 2013
Host : "ubuntu"
fileName::stripInvalid() called for invalid fileName /home/toshiba/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/UntitledFolder/airFoil2D
For debug level (= 2) > 1 this is considered fatal
Aborted
toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/Untitled Folder/airFoil2D$
Old   June 11, 2013, 04:28
Default foamToVTK
hhh
kunar
hi bruno, i got the mistake, i change the UntitledFolder to ku, now its work fine, during run the simple foam i got this,
what ever i mention in red colour it shows any error?
toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/ku/airFoil2D$ simpleFoam
Exec : simpleFoam
Date : Jun 11 2013
Time : 14:42:35
Host : "ubuntu"
Case : /home/toshiba/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/ku/airFoil2D
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model SpalartAllmaras
SpalartAllmarasCoeffs
sigmaNut 0.66666;
kappa 0.41;
Cb1 0.1355;
Cb2 0.622;
Cw2 0.3;
Cw3 2;
Cv1 7.1;
Cv2 5;
No field sources present
SIMPLE: convergence criteria
field p tolerance 1e-05
field U tolerance 1e-05
field nuTilda tolerance 1e-05
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 0.999993, Final residual = 0.0558381, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0760732, No Iterations 2
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0991895, No Iterations 39
time step continuity errors : sum local = 0.00119979, global = 6.26709e-16, cumulative = 6.26709e-16
smoothSolver: Solving for nuTilda, Initial residual = 0.999999, Final residual = 0.0701398, No Iterations 4
ExecutionTime = 36.7 s ClockTime = 37 s
forces output:
forces(pressure,viscous)((257697 5.20299e+06 7.66604e-16),(6.53254 1.33905 -1.89121e-21))
moment(pressure,viscous)((-3.39084e-17 -1.06156e-16 2.50963e+06),(4.47879e-23 -2.14236e-22 0.66735))
forceCoeffs output:
Cm = 901.996
Cd = 415.85
Cl = 1857.68
Cl(f) = 1830.84
Cl(r) = 26.8427
Time = 2
smoothSolver: Solving for Ux, Initial residual = 0.623192, Final residual = 0.0517858, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.445407, Final residual = 0.0284221, No Iterations 4
GAMG: Solving for p, Initial residual = 0.711508, Final residual = 0.0608906, No Iterations 11
time step continuity errors : sum local = 0.000802196, global = 1.48748e-15, cumulative = 2.11418e-15
smoothSolver: Solving for nuTilda, Initial residual = 0.258696, Final residual = 0.0187245, No Iterations 4
ExecutionTime = 45.88 s ClockTime = 46 s
forces output:
forces(pressure,viscous)((168327 3.88357e+06 2.72499e-16),(23.6262 2.65695 -2.24632e-21))
moment(pressure,viscous)((-2.10668e-17 -5.5126e-17 1.89813e+06),(5.34685e-23 -6.75307e-22 1.37948))
forceCoeffs output:
Cm = 682.213
Cd = 301.9
Cl = 1385.1
Cl(f) = 1374.76
Cl(r) = 10.3358
I hope everthing is fine its keep on running like this i got cl,cd,cm, please let me what i mention in red colour.
Old   June 15, 2013, 11:21
Bruno Santos
Hi Kumar,
I'll try to answer at least some of these questions on your other thread, where you've asked them again: http://www.cfd-online.com/Forums/ope...hat-means.html
Best regards,
Bruno
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
