Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Time averaging a product of fluctuations <u'T'>
Old   November 14, 2013, 15:35
Default Time averaging a product of fluctuations <u'T'>
Laurien Vandewalle
lavdwall is on a distinguished road
Hi everyone,
I would like to calculate turbulent heat fluxes, which are defined as the time averages of the velocity and temperature fluctuations:
<u' T'> where <..> denotes a time averaging operation, and u' and T' are respectively the velocity and temperature fluctuations.
Is there an easy solution to achieve this? I tried with the fieldAverage function in the controlDict but there it is only possible to calculate the prime-squared mean values of 1 field, e.g. <u'u'>. Someone has a solution?
Kind regards,
Laurien
lavdwall is offline   Reply With Quote
Old   November 15, 2013, 02:18
Bernhard
Bernhard is on a distinguished road
You can try to create a field U*T somehow, then <u'T'>=<UT>-<U><T>, where I assume you are tracking the mean quantities anyhow.
Bernhard is offline   Reply With Quote
Old   January 23, 2014, 04:48
Peter
palmerlee is on a distinguished road
Hi, Laurien!
Have you found a solution yet? I want to calculate <u' T'> too. It would be very kind of you to share some information about this problem.
Best regards,
Peter
palmerlee is offline   Reply With Quote
Old   April 29, 2015, 06:16
Agustín Villa
agustinvo is on a distinguished road
Hello
were you able to find a solution for this? I am wondering I have to modify the fieldAverage function, but it's not so easy to understand the code...
agustinvo is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
