Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
plateHole and mapFields - tutorial exercise with FOAM IO FATAL ERROR
Old   November 6, 2013, 07:48
Default plateHole and mapFields - tutorial exercise with FOAM IO FATAL ERROR
G. Wind
Gwind is on a distinguished road
Hi folks,
in execise 2.2.4.1 of the tutorial, I manage to refine the mesh for plateHole. However, when I try to map the final coarse mesh results from section 2.2.3 to the initial conditions for the fine mesh, I get the following answer.
--> FOAM FATAL IO ERROR:
size 1000 is not equal to the given value of 4000
file: /home/yoda/OpenFOAM/yoda-2.2.1/run/tutorials/stressAnalysis/solidDisplacementFoam/plateHolefino/100/sigmaxz from line 18 to line 1145.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
I understand that sizes should not be the same, because of mesh refining. So, why is it giving this error?
Thanks in advance.
Gwind is offline   Reply With Quote
Old   November 20, 2013, 09:23
Vincent Leroy
leroyv is on a distinguished road
Dear Gwind,
I had this exact same error. While I'm not certain of what caused it to happen, I noticed that things went okay when I deleted every run directories (0/, 20/, ..., 100/) in the directory of the refined mesh case (plateHoleFineMesh/ in my case). I hope this helps you.
V
leroyv is offline   Reply With Quote
Old   November 26, 2013, 06:19
G. Wind
Thanks a lot!
Gwind
