[swak4Foam] How to use funkySetFields for surface scalar 'phi'?
Like Tree1Likes
  • 1 Post By gschaider
Old   March 19, 2014, 17:59
Default How to use funkySetFields for surface scalar 'phi'?
Tony
wzx1989221 is on a distinguished road
Hi everyone,
I met a problem when using funkySetFields for surface scalar field 'phi'. Basically I want to non-dimensionalise my case through dividing the fields by its reference values. I used the code below for velocity and pressure fields and they worked fine.
funkySetFields -field p -keepPatches -expression 'p/0.030625' -time 63 -condition "mag(vector(pos().x,pos().y,0))<=1.0"
funkySetFields -field U -keepPatches -expression 'U/0.175' -time 63 -condition "mag(vector(pos().x,pos().y,0))<=1.0"
However, when it comes to the surface scalar field 'phi', the error turned up like this:
--> FOAM FATAL ERROR:
 Parser Error for driver FieldValueExpressionDriver at "1.5-11" :"syntax error, unexpected number"
"phi/0.01575"
Context of the error:
- Driver constructed from scratch
  Evaluating expression "phi/0.01575"
    From function parsingValue
    in file lnInclude/CommonValueExpressionDriverI.H at line 1081.
This is the code I use for phi:
funkySetFields -field phi -expression 'phi/0.01575' -time 63
Why I can't use funkySetFields for phi? Is there anything wrong in my code?
I really appreciate it if someone could give me a hand. Thank you very much.
Kind regards,
Tony
wzx1989221 is offline   Reply With Quote
Old   March 20, 2014, 14:18
Assistant Moderator
Bernhard Gschaider
Originally Posted by wzx1989221 View Post
Hi everyone,
"phi/0.01575"
Kind regards,
Tony
You can. But phi is a surfaceScalarField and 0.01575 is (for technical reasons) a volScalarField. So 'phi/interpolate(0.01575)' should do the trick. Have a look at Documentation/swak4FoamReference.org for details.
BTW: for a condition you'll want to use fpos() for the face positions
letzel likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 20, 2014, 17:36
Tony
Dear Bernhard,
Thank you very much for the solution and your kind notice.
I tried with interpolate() and it worked for internal fields, however, I couldn't change the values on the boundary (BTW, I am using cyclic boundary condition). Is it possible to get the flux value on boundary changed as well?
Thanks and regards,
Tony
Old   March 21, 2014, 18:38
Assistant Moderator
Bernhard Gschaider
Dear Bernhard,
Currently no. The parser underneath funkySetFields only works on internalFields (and changing that requires a lot of work for that one application). funkySetBoundaryFields might work
Old   March 22, 2014, 07:30
Tony
Hi Bernhard,
Many thanks for your kind reply. I will have a look at that.
Kind regards,
Tony
error, funkysetfields, phi
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Division by zero exception - loop over scalarField Pat84 OpenFOAM Programming & Development 6 February 18, 2017 05:57
Issue symmetryPlane 2.5d extruded airfoil simulation 281419 OpenFOAM Running, Solving & CFD 5 November 28, 2015 13:09
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 06:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
