Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculating the static pressure on HAWT blades?
Old   April 10, 2016, 21:09
Default Calculating the static pressure on HAWT blades?
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello Fomers,
I hope that you are all well. I have been trying to verify some resutls on a paper about wind turbines using AD model. The code has to file, sampleDictForce and velocity. I have never used this utility before, but anyway I intuitively used the command "sample" after finishing the simulation. The command sample has given me the following;
"From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87."
I don't know what exactly whether this from the version that I am using or misinterpretation of using this utility. Has anybody of you used this utility for similar purposes?
I would really appreciate any help or document deals with similar post-processing.
Thank you all,
tareqkh is offline   Reply With Quote
Old   April 10, 2016, 21:57
Default Answer!
tareqkh's Avatar
CFD
Search for an example sampleDict file in OpenFOAM directory and copy it to system and adjust it.
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 14:42
Static Pressure vs Hydrostatic Pressure MissCFD CFX 3 August 12, 2014 23:29
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
