Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallGradU and wallShearStress, inconsistent result for RAS model
Old   August 19, 2014, 11:08
Question wallGradU and wallShearStress, inconsistent result for RAS model
Lu ZHOU
lzhou is on a distinguished road
I am doing a simple simulation of water flowing on a plate with RAS k-epsilon model.
My goal is to verify the simulation results with different roughness height on the surface of the plate and to calculate the wall shear stress of each case.
However, the utility wallGradU gives (36.5451 -8.58721e-05 0.000132998) for one point on the bottom wall and the utility wallShearStress gives (-0.000808236 3.08435e-09 -2.97856e-09) at this point. As I am doing a simulation of water so the dynamic (shear) viscosity is 8.9e-4 Pa·s. And the wall shear stress can be calculated by the equation:
So I think at this point ,the wall shear stress should be 8.9e-4*36.5451=0.0325 pa.
I would like to ask why there is the difference between the results of wallGradU and wallShearStress ? If possible, could anyone tell me the equations used in OpenFoam to calculate the wall shear stress ? Thanks !
lzhou is offline   Reply With Quote
Old   August 19, 2014, 11:22
Lu ZHOU
To add some details. The results I got is for a smooth plate with nukRoughWallFunction and Ks=0 Cs=0.5 as the boundary condition at the bottom wall. And I did not find a place to add the density of the fluid into the simulation so I guess the wall shear stress is calculated with the kinematic viscosity rather than the dynamic viscosity. Or it assumes that the density is 1 kg/m^3. I am a starter of CFD and OpenFoam so can someone help me please. Thanks !
ras compressible, wallgradu, wallshearstress
wallGradU or wallShearStress on Time-Averaged Velocity Field minger OpenFOAM Post-Processing 6 November 7, 2019 05:30
wallShearStress, wallGradU are inconsistent dancfd OpenFOAM Post-Processing 5 July 18, 2018 08:33
calculate and sample wallGradU & wallShearStress every output time ArathoN OpenFOAM Post-Processing 8 July 11, 2018 12:14
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 09:53
wallShearStress VS wallGradU bigrock OpenFOAM Post-Processing 0 July 2, 2013 05:54
