How can I calculate gradT and Nusselt for this problem |
October 30, 2014, 18:30 |
sajad
Rep Power: 12 |
I changed the icoFoam to icoHeatFoam with add energy equation to it.also I change wallheatflux to wallHeatFluxLaminar.now I want to calculate gradT and Nusselt number around the block.how can I do this?
I cant download foamCalcEx because of Region denied. I attached the my case rtnx for any help |
October 30, 2014, 19:36 |
sajad
Rep Power: 12 |
I calculated magGradT and wallHeatFlux.now just I want to calculate Nusselt Number.I know:
Nuss=wallHeatFlux/magGradT but I dont know how I compute it in openFoam.I has both wallHeatFlux and magGradT.I just need to do a fraction.how can I do it? |
November 8, 2014, 23:45 |
Raghav
Rep Power: 11 |
Hi sajad6,
How did you calculate gradT? I'm also trying to calculate it on the wall. Thanks in advance! |
November 9, 2014, 02:02 |
calculating gradT
sajad
Rep Power: 12 |
Hi dear raghav
you can download foamCalcEx from below link and compile it: http://openfoamwiki.net/index.php/Contrib_foamCalcEx after you compile it you can calculate grad T after processing by type the code below: Code:
foamCalcEx grad T |
November 9, 2014, 19:26 |
Raghav
Rep Power: 11 |
Thank you very much sajad6
Do you know how I can get the magnitude of the gradient vector directly? I just want it on the walls |
November 10, 2014, 11:50 |
sajad
Rep Power: 12 |
Yes.
open your case in terminal and type: Code:
foamCalc magGrad T |
Nusselt Number problem | Goutam | OpenFOAM Running, Solving & CFD | 5 | July 12, 2012 05:14 |
