[swak4Foam] funkyDoCalc mass flow over stl surface?
Old   November 28, 2014, 07:50
Default funkyDoCalc mass flow over stl surface?
Lourenço SM
lourencosm is on a distinguished road
Does anyone knows how to calculate the mass flow over a stl surface with funkyDoCalc?
After searching, I have tried this script but doesn't works:
flowBeforeSet
valueType surface;
surfaceName planoCristaA;
surface {
type sampledTriSurfaceMesh;
surface planoCrista.stl;
source cells; // sample cells or boundaryFaces
interpolate false;
expression "alpha1*mag(U*Sf() )";
accumulations (
sum
The error:
Time = 100
flowBeforeSet : --> FOAM Warning :
From function SampledSurface &SurfacesRepository::getSurface
in file repositories/SurfacesRepository.C at line 138
Already got a surface named planoCristaA. There is a specification for the surface here which is ignored. It is:
source cells;
interpolate false;
sum=128.178
Thank you,
Lourenço
lourencosm is offline   Reply With Quote
funkydocalc, mass flow, surface, swak4foam
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Surface Integrals of Species Mass Flow to Wall Incorrect koad FLUENT 4 January 12, 2016 16:38
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 17:57
