Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
air flux through a boundary with air-water mixture
Like Tree1Likes
  • 1 Post By cutter
Old   July 8, 2013, 09:12
Default air flux through a boundary with air-water mixture
Hale
Hale is on a distinguished road
I have calculated the total flux through boundaries of my model but I further need to calculate the fraction of air flux through the boundaries with air-water mixture. Is there any way to find the air fraction?
Thanks a lot
Hale
Hale is offline   Reply With Quote
Old   July 8, 2013, 09:19
cutter is on a distinguished road
which solver do you use and how is you processing done (calculation within solver or via function objects)? You probably need to account for the alpha/alpha1 values.
Cutter
cutter is offline   Reply With Quote
Old   July 8, 2013, 09:30
Hale
Originally Posted by cutter View Post
Cutter
Thanks for your reply.
I'm using InterFoam and the calculation is done via a function object (calcMassFlow that uses the phi file to calculate the fluxes through boundaries; http://www.cfd-online.com/Forums/ope...-boundary.html)
You are definitely right. I have to multiply the total mass flux (at each boundary and time step) with the corresponding alpha1 values but is it possible to do it after the calculation is performed? How can I distinguish the alpha1 values for different boundaries?
Old   July 8, 2013, 09:44
This should be possible by using the faceSource function object:
    myFuncObj
        type            faceSource;
        functionObjectLibs ("libfieldFunctionObjects.so");
        outputControl   timeStep;
        log             true;
        // Output field values as well
        valueOutput     false;
        source          patch;
        sourceName      outlet; // replace patch name!!!
        operation       sum;
        fields
            rho*phi*alpha // maybe fix eqn. for your purpose!!!
Feedback welcome!
Cutter
Old   July 8, 2013, 09:54
Hale
    myFuncObj
        type            faceSource;
        log             true;
        valueOutput     false;
        source          patch;
        operation       sum;
        fields
Feedback welcome!
Cutter
Sorry for asking simple questions, I'm very new to OpenFOAM. Where should I place this code? and do I need the log file from the calculation in order to use this function? I didn't restore the data in a log file when I ran the simulations.
Old   July 8, 2013, 10:20
Function objects are registered within a subdict called 'functions' in $CASE/system/controlDict.
See http://foam.sourceforge.net/docs/cpp/a00002.html and https://www.hpc.ntnu.no/display/hpc/...Postprocessing for example.
gregjunqua likes this.
Old   July 8, 2013, 10:59
Hale
Thanks a lot. I ran the simulations for several seconds now (by having the code you gave in the system/controlDict). But how can I access the results? I mean the air fluxes?
Old   July 8, 2013, 11:13
It should be written to the solver's text output at the end of each time step.
Old   July 8, 2013, 11:46
Hale
I'm really sorry but nothing is written to the log file. I have attached my controlDict file to this message. I will really be grateful if you could tell me what I have done wrong.
Old   July 9, 2013, 04:06
Hale
I have now fixed the problem with getting output from the solver. When I set rho*phi in the faceSource object function it gives the total flux at each time step but when I add the alpha1 (i.e. rho*phi*alpha1) it gives nothing in the output file. How can this problem be fixed?
Thanks
\Hale
Old   December 15, 2014, 04:05
sorry for the really late reply. Maybe it still helps you or any other reader of this thread.
Have a look at https://github.com/OpenFOAM/OpenFOAM...em/controlDict for a working example for OpenFOAM 2.3.x (there are tutorial cases for other versions of OF as well)!
The data will be written into ASCII text files (simple CSV format, with file extension *.dat) in a directory called postProcessing within the root directory of your case.
Feel free to ask follow up questions if necessary, hopefully the answer will come faster next time.
Cutter
Old   January 6, 2015, 12:56
Matthew Denno
mgdenno is on a distinguished road
I have been playing around with this myself and I haven't been able to multiply rho*phi by alpha using faceSource.
One solution is to use swak4foam instead of faceSource. I found this somewhere on the forums, but I can't remember which post it came from.
https://openfoamwiki.net/index.php/Contrib/swak4Foam
    inlet
        type                swakExpression;
        valueType           patch;
        patchName           c_inlet;
        aliases{alpha alpha.water;}
        verbose             true;
        expression          "alpha*U&Sf()";
        accumulations       ( sum );
        outputControlMode outputTime;
        outputInterval 1;
mgdenno is offline   Reply With Quote
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
Simulating A water bubble in air with periodic boundary condition cubicmatrixist Main CFD Forum 0 October 14, 2010 12:26
water and air interface boundary Shivakanth Main CFD Forum 2 September 25, 2008 09:11
Mixture model - water droplet + air - EVAPORATION bohis FLUENT 4 January 25, 2008 11:04
