sample utility of OF2.3.1 provides less points |
April 1, 2015, 09:38 |
anonymous
Rep Power: 12 |
Hi all
I was using OF v2.2.1 and I did the post-processing with the sample utility, with a cloud of points. Results were nice. After upgrading to v2.3.1, I run this utility on the same CFD results (and same sampleDict) but now I get less points. I tested on different models (i.e. different sampleDicts) and I always get less points. Also, the number of missing points seems random among cases but repeating the sample utility twice in the same case, gives me the same missing points. Any ideas? Thanks in advance |
August 21, 2015, 11:39 |
Diogo Ramalho
Hy,
I have the same problem with sampleDict. Trying to plot the pressure around an airfoil using a point cloud with the right coordinates. Since I get the coordinates of the points from a geometry that is converted into *.stl files I have tried to create an offset to this geometry to avoid some coordinates that might get into the geometry in my *.stl file (the conversion to *.stl could put the points inside the geometry) but got no success. I also have tried 50, 100, and 200 points but the output is always half the numbers of point I input to sampleDict. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object sampleDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Set output format : choice of // xmgr // jplot // gnuplot // raw // vtk // ensight // csv setFormat raw; // Surface output format. Choice of // null : suppress output // ensight : Ensight Gold format, one field per case file // foamFile : separate points, faces and values file // dx : DX scalar or vector format // vtk : VTK ascii format // raw : x y z value format for use with e.g. gnuplot 'splot'. // // Note: // other formats such as obj, stl, etc can also be written (by proxy) // but without any values! surfaceFormat vtk; // optionally define extra controls for the output formats formatOptions { ensight { format ascii; } } // interpolationScheme. choice of // cell : use cell-centre value only; constant over cells // (default) // cellPoint : use cell-centre and vertex values // cellPointFace : use cell-centre, vertex and face values. // pointMVC : use point values only (Mean Value Coordinates) // cellPatchConstrained : like 'cell' but uses cell-centre except on // boundary faces where it uses the boundary value. // For use with e.g. patchCloudSet. // 1] vertex values determined from neighbouring cell-centre values // 2] face values determined using the current face interpolation scheme // for the field (linear, gamma, etc.) interpolationScheme cellPoint; // Fields to sample. fields ( p U magU ); // Set sampling definition: choice of // uniform evenly distributed points on line // face one point per face intersection // midPoint one point per cell, inbetween two face intersections // midPointAndFace combination of face and midPoint // // polyLine specified points, not nessecary on line, uses // tracking // cloud specified points, uses findCell // triSurfaceMeshPointSet points of triSurface // // axis: how to write point coordinate. Choice of // - x/y/z: x/y/z coordinate only // - xyz: three columns // (probably does not make sense for anything but raw) // - distance: distance from start of sampling line (if uses line) or // distance from first specified sampling point // // type specific: // uniform, face, midPoint, midPointAndFace : start and end coordinate // uniform: extra number of sampling points // polyLine, cloud: list of coordinates // patchCloud: list of coordinates and set of patches to look for nearest // patchSeed: random sampling on set of patches. Points slightly off // face centre. sets ( /* lineX1 { type uniform; axis distance; //- cavity. Slightly perturbed so not to align with face or edge. start (0.0201 0.05101 0.00501); end (0.0601 0.05101 0.00501); nPoints 10; } lineX2 { type face; axis x; //- cavity start (0.0001 0.0525 0.00501); end (0.0999 0.0525 0.00501); } */ somePoints { type cloud; axis xyz; points ((8.4638 -1.6865 0)(8.4638 -1.6865 0)(8.2362 -1.5877 0)(8.2362 -1.5877 0)(8.0081 -1.49 0)(8.0081 -1.49 0)(7.7796 -1.3933 0)(7.7796 -1.3933 0)(7.5506 -1.2976 0)(7.5506 -1.2976 0)(7.3213 -1.203 0)(7.3213 -1.203 0)(7.0915 -1.1093 0)(7.0915 -1.1093 0)(6.8614 -1.0165 0)(6.8614 -1.0165 0)(6.6308 -0.9247 0)(6.6308 -0.9247 0)(6.3999 -0.8338 0)(6.3999 -0.8338 0)(6.1687 -0.7439 0)(6.1687 -0.7439 0)(5.9371 -0.6549 0)(5.9371 -0.6549 0)(5.7051 -0.5668 0)(5.7051 -0.5668 0)(5.4727 -0.4797 0)(5.4727 -0.4797 0)(5.24 -0.3936 0)(5.24 -0.3936 0)(5.007 -0.3084 0)(5.007 -0.3084 0)(4.7735 -0.2243 0)(4.7735 -0.2243 0)(4.5397 -0.1413 0)(4.5397 -0.1413 0)(4.3054 -0.0595 0)(4.3054 -0.0595 0)(4.0708 0.0212 0)(4.0708 0.0212 0)(3.8357 0.1007 0)(3.8357 0.1007 0)(3.6002 0.1788 0)(3.6002 0.1788 0)(3.3642 0.2556 0)(3.3642 0.2556 0)(3.1278 0.3308 0)(3.1278 0.3308 0)(2.8908 0.4044 0)(2.8908 0.4044 0)(2.6533 0.4764 0)(2.6533 0.4764 0)(2.4153 0.5465 0)(2.4153 0.5465 0)(2.1767 0.6146 0)(2.1767 0.6146 0)(1.9375 0.6806 0)(1.9375 0.6806 0)(1.6977 0.7442 0)(1.6977 0.7442 0)(1.4572 0.8054 0)(1.4572 0.8054 0)(1.2161 0.8639 0)(1.2161 0.8639 0)(0.9742 0.9194 0)(0.9742 0.9194 0)(0.7316 0.9716 0)(0.7316 0.9716 0)(0.4883 1.0203 0)(0.4883 1.0203 0)(0.2443 1.0651 0)(0.2443 1.0651 0)(-0.0005 1.1056 0)(-0.0005 1.1056 0)(-0.2461 1.1412 0)(-0.2461 1.1412 0)(-0.4924 1.1715 0)(-0.4924 1.1715 0)(-0.7393 1.1957 0)(-0.7393 1.1957 0)(-0.9868 1.2129 0)(-0.9868 1.2129 0)(-1.2348 1.222 0)(-1.2348 1.222 0)(-1.4829 1.2216 0)(-1.4829 1.2216 0)(-1.7307 1.2097 0)(-1.7307 1.2097 0)(-1.9774 1.1833 0)(-1.9774 1.1833 0)(-2.2213 1.138 0)(-2.2213 1.138 0)(-2.4586 1.0663 0)(-2.4586 1.0663 0)(-2.6799 0.9551 0)(-2.6799 0.9551 0)(-2.8576 0.7842 0)(-2.8576 0.7842 0)(-2.9359 0.552 0)(-2.9359 0.552 0)(-2.8875 0.311 0)(-2.8875 0.311 0)(-2.7523 0.104 0)(-2.7523 0.104 0)(-2.5753 -0.0696 0)(-2.5753 -0.0696 0)(-2.377 -0.2186 0)(-2.377 -0.2186 0)(-2.1662 -0.3495 0)(-2.1662 -0.3495 0)(-1.9474 -0.4663 0)(-1.9474 -0.4663 0)(-1.7228 -0.5718 0)(-1.7228 -0.5718 0)(-1.4941 -0.6679 0)(-1.4941 -0.6679 0)(-1.2621 -0.756 0)(-1.2621 -0.756 0)(-1.0276 -0.8371 0)(-1.0276 -0.8371 0)(-0.791 -0.912 0)(-0.791 -0.912 0)(-0.5528 -0.9815 0)(-0.5528 -0.9815 0)(-0.3133 -1.0461 0)(-0.3133 -1.0461 0)(-0.0725 -1.1062 0)(-0.0725 -1.1062 0)(0.1691 -1.1623 0)(0.1691 -1.1623 0)(0.4117 -1.2147 0)(0.4117 -1.2147 0)(0.6549 -1.2637 0)(0.6549 -1.2637 0)(0.8988 -1.3097 0)(0.8988 -1.3097 0)(1.1432 -1.3527 0)(1.1432 -1.3527 0)(1.388 -1.3932 0)(1.388 -1.3932 0)(1.6332 -1.4312 0)(1.6332 -1.4312 0)(1.8787 -1.4669 0)(1.8787 -1.4669 0)(2.1246 -1.5006 0)(2.1246 -1.5006 0)(2.3707 -1.5322 0)(2.3707 -1.5322 0)(2.617 -1.5621 0)(2.617 -1.5621 0)(2.8636 -1.5902 0)(2.8636 -1.5902 0)(3.1103 -1.6168 0)(3.1103 -1.6168 0)(3.3571 -1.6418 0)(3.3571 -1.6418 0)(3.6041 -1.6654 0)(3.6041 -1.6654 0)(3.8513 -1.6877 0)(3.8513 -1.6877 0)(4.0985 -1.7087 0)(4.0985 -1.7087 0)(4.3459 -1.7285 0)(4.3459 -1.7285 0)(4.5933 -1.7471 0)(4.5933 -1.7471 0)(4.8408 -1.7646 0)(4.8408 -1.7646 0)(5.0884 -1.781 0)(5.0884 -1.781 0)(5.3361 -1.7964 0)(5.3361 -1.7964 0)(5.5838 -1.8107 0)(5.5838 -1.8107 0)(5.8316 -1.824 0)(5.8316 -1.824 0)(6.0794 -1.8364 0)(6.0794 -1.8364 0)(6.3273 -1.8477 0)(6.3273 -1.8477 0)(6.5752 -1.858 0)(6.5752 -1.858 0)(6.8231 -1.8673 0)(6.8231 -1.8673 0)(7.0711 -1.8756 0)(7.0711 -1.8756 0)(7.3192 -1.8829 0)(7.3192 -1.8829 0)(7.5672 -1.8891 0)(7.5672 -1.8891 0)(7.8153 -1.8942 0)(7.8153 -1.8942 0)(8.0634 -1.8982 0)(8.0634 -1.8982 0)(8.3115 -1.901 0)(8.3115 -1.901 0)(8.5597 -1.9026 0)(8.5597 -1.9026 0)(8.6904 -1.7873 0)(8.6904 -1.7873 0)); } /* somePatchPoints { // Sample nearest points on selected patches. Looks only up to // maxDistance away. Any sampling point not found will get value // pTraits<Type>::max (usually VGREAT) // Use with interpolations: // - cell (cell value) // - cellPatchConstrained (boundary value) // - cellPoint (interpolated boundary value) type patchCloud; axis xyz; points ((0.049 0.099 0.005)(0.051 0.054 0.005)); maxDistance 0.1; // maximum distance to search patches (".*Wall.*"); } patchSeed { type patchSeed; patches (".*Wall.*"); // Number of points to seed. Divided amongst all processors according // to fraction of patches they hold. maxPoints 100; } */ ); /* // Surface sampling definition // // 1] patches are not triangulated by default // 2] planes are always triangulated // 3] iso-surfaces are always triangulated surfaces ( constantPlane { type plane; // always triangulated basePoint (0.0501 0.0501 0.005); normalVector (0.1 0.1 1); //- Optional: restrict to a particular zone // zone zone1; //- Optional: do not triangulate (only for surfaceFormats that support // polygons) //triangulate false; } interpolatedPlane { type plane; // always triangulated // make plane relative to the coordinateSystem (Cartesian) coordinateSystem { origin (0.0501 0.0501 0.005); } basePoint (0 0 0); normalVector (0.1 0.1 1); interpolate true; } walls_constant { type patch; patches ( ".*Wall.*" ); // Optional: whether to leave as faces (=default) or triangulate // triangulate false; } walls_interpolated { type patch; patches ( ".*Wall.*" ); interpolate true; // Optional: whether to leave as faces (=default) or triangulate // triangulate false; } nearWalls_interpolated { // Sample cell values off patch. Does not need to be the near-wall // cell, can be arbitrarily far away. type patchInternalField; patches ( ".*Wall.*" ); interpolate true; // Optional: specify how to obtain sampling points from the patch // face centres (default is 'normal') // // //- Specify distance to offset in normal direction offsetMode normal; distance 0.1; // // //- Specify single uniform offset // offsetMode uniform; // offset (0 0 0.0001); // // //- Specify offset per patch face // offsetMode nonuniform; // offsets ((0 0 0.0001) (0 0 0.0002)); // Optional: whether to leave as faces (=default) or triangulate // triangulate false; } interpolatedIso { // Iso surface for interpolated values only type isoSurface; // always triangulated isoField rho; isoValue 0.5; interpolate true; //zone ABC; // Optional: zone only //exposedPatchName fixedWalls; // Optional: zone only // regularise false; // Optional: do not simplify // mergeTol 1e-10; // Optional: fraction of mesh bounding box // to merge points (default=1e-6) } constantIso { // Iso surface for constant values. // Triangles guaranteed not to cross cells. type isoSurfaceCell; // always triangulated isoField rho; isoValue 0.5; interpolate false; regularise false; // do not simplify // mergeTol 1e-10; // Optional: fraction of mesh bounding box // to merge points (default=1e-6) } triangleCut { // Cutingplane using iso surface type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { basePoint (0.4 0 0.4); normalVector (1 0.2 0.2); } interpolate true; //zone ABC; // Optional: zone only //exposedPatchName fixedWalls; // Optional: zone only // regularise false; // Optional: do not simplify // mergeTol 1e-10; // Optional: fraction of mesh bounding box // to merge points (default=1e-6) } distance { // Isosurface from signed/unsigned distance to surface type distanceSurface; signed true; // Definition of surface surfaceType triSurfaceMesh; surfaceName integrationPlane.stl; // Distance to surface distance 0.0; //cell false;// optional: use isoSurface instead // of isoSurfaceCell interpolate false; regularise false; // Optional: do not simplify // mergeTol 1e-10; // Optional: fraction of mesh bounding box // to merge points (default=1e-6) } triSurfaceSampling { // Sampling on triSurface type sampledTriSurfaceMesh; surface integrationPlane.stl; source boundaryFaces; // What to sample: cells (nearest cell) // insideCells (only triangles inside cell) // boundaryFaces (nearest boundary face) interpolate true; } ); */ // *********************************************************************** // Thanks in advance. Diogo Ramalho edit: Got the problem solved. It was my fault getting the coordinates from points. No issues with sampleDict now. Sorry. Last edited by dramalho; August 21, 2015 at 13:09. |
August 21, 2015, 12:32 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@aCFDuser: Without at least a test case, there isn't much I can do. @Diogo: I hate to state the obvious, but this is what matters from the file you provided: Code:
somePoints { type cloud; axis xyz; points ((8.4638 -1.6865 0)(8.4638 -1.6865 0)(8.2362 -1.5877 0)(8.2362 -1.5877 0)(8.0081 -1.49 0)(8.0081 -1.49 0)(7.7796 -1.3933 0)(7.7796 -1.3933 0)(7.5506 -1.2976 0)(7.5506 -1.2976 0)(7.3213 -1.203 0)(7.3213 -1.203 0)(7.0915 -1.1093 0)(7.0915 -1.1093 0)(6.8614 -1.0165 0)(6.8614 -1.0165 0)(6.6308 -0.9247 0)(6.6308 -0.9247 0)(6.3999 -0.8338 0)(6.3999 -0.8338 0)(6.1687 -0.7439 0)(6.1687 -0.7439 0)(5.9371 -0.6549 0)(5.9371 -0.6549 0)(5.7051 -0.5668 0)(5.7051 -0.5668 0)(5.4727 -0.4797 0)(5.4727 -0.4797 0)(5.24 -0.3936 0)(5.24 -0.3936 0)(5.007 -0.3084 0)(5.007 -0.3084 0)(4.7735 -0.2243 0)(4.7735 -0.2243 0)(4.5397 -0.1413 0)(4.5397 -0.1413 0)(4.3054 -0.0595 0)(4.3054 -0.0595 0)(4.0708 0.0212 0)(4.0708 0.0212 0)(3.8357 0.1007 0)(3.8357 0.1007 0)(3.6002 0.1788 0)(3.6002 0.1788 0)(3.3642 0.2556 0)(3.3642 0.2556 0)(3.1278 0.3308 0)(3.1278 0.3308 0)(2.8908 0.4044 0)(2.8908 0.4044 0)(2.6533 0.4764 0)(2.6533 0.4764 0)(2.4153 0.5465 0)(2.4153 0.5465 0)(2.1767 0.6146 0)(2.1767 0.6146 0)(1.9375 0.6806 0)(1.9375 0.6806 0)(1.6977 0.7442 0)(1.6977 0.7442 0)(1.4572 0.8054 0)(1.4572 0.8054 0)(1.2161 0.8639 0)(1.2161 0.8639 0)(0.9742 0.9194 0)(0.9742 0.9194 0)(0.7316 0.9716 0)(0.7316 0.9716 0)(0.4883 1.0203 0)(0.4883 1.0203 0)(0.2443 1.0651 0)(0.2443 1.0651 0)(-0.0005 1.1056 0)(-0.0005 1.1056 0)(-0.2461 1.1412 0)(-0.2461 1.1412 0)(-0.4924 1.1715 0)(-0.4924 1.1715 0)(-0.7393 1.1957 0)(-0.7393 1.1957 0)(-0.9868 1.2129 0)(-0.9868 1.2129 0)(-1.2348 1.222 0)(-1.2348 1.222 0)(-1.4829 1.2216 0)(-1.4829 1.2216 0)(-1.7307 1.2097 0)(-1.7307 1.2097 0)(-1.9774 1.1833 0)(-1.9774 1.1833 0)(-2.2213 1.138 0)(-2.2213 1.138 0)(-2.4586 1.0663 0)(-2.4586 1.0663 0)(-2.6799 0.9551 0)(-2.6799 0.9551 0)(-2.8576 0.7842 0)(-2.8576 0.7842 0)(-2.9359 0.552 0)(-2.9359 0.552 0)(-2.8875 0.311 0)(-2.8875 0.311 0)(-2.7523 0.104 0)(-2.7523 0.104 0)(-2.5753 -0.0696 0)(-2.5753 -0.0696 0)(-2.377 -0.2186 0)(-2.377 -0.2186 0)(-2.1662 -0.3495 0)(-2.1662 -0.3495 0)(-1.9474 -0.4663 0)(-1.9474 -0.4663 0)(-1.7228 -0.5718 0)(-1.7228 -0.5718 0)(-1.4941 -0.6679 0)(-1.4941 -0.6679 0)(-1.2621 -0.756 0)(-1.2621 -0.756 0)(-1.0276 -0.8371 0)(-1.0276 -0.8371 0)(-0.791 -0.912 0)(-0.791 -0.912 0)(-0.5528 -0.9815 0)(-0.5528 -0.9815 0)(-0.3133 -1.0461 0)(-0.3133 -1.0461 0)(-0.0725 -1.1062 0)(-0.0725 -1.1062 0)(0.1691 -1.1623 0)(0.1691 -1.1623 0)(0.4117 -1.2147 0)(0.4117 -1.2147 0)(0.6549 -1.2637 0)(0.6549 -1.2637 0)(0.8988 -1.3097 0)(0.8988 -1.3097 0)(1.1432 -1.3527 0)(1.1432 -1.3527 0)(1.388 -1.3932 0)(1.388 -1.3932 0)(1.6332 -1.4312 0)(1.6332 -1.4312 0)(1.8787 -1.4669 0)(1.8787 -1.4669 0)(2.1246 -1.5006 0)(2.1246 -1.5006 0)(2.3707 -1.5322 0)(2.3707 -1.5322 0)(2.617 -1.5621 0)(2.617 -1.5621 0)(2.8636 -1.5902 0)(2.8636 -1.5902 0)(3.1103 -1.6168 0)(3.1103 -1.6168 0)(3.3571 -1.6418 0)(3.3571 -1.6418 0)(3.6041 -1.6654 0)(3.6041 -1.6654 0)(3.8513 -1.6877 0)(3.8513 -1.6877 0)(4.0985 -1.7087 0)(4.0985 -1.7087 0)(4.3459 -1.7285 0)(4.3459 -1.7285 0)(4.5933 -1.7471 0)(4.5933 -1.7471 0)(4.8408 -1.7646 0)(4.8408 -1.7646 0)(5.0884 -1.781 0)(5.0884 -1.781 0)(5.3361 -1.7964 0)(5.3361 -1.7964 0)(5.5838 -1.8107 0)(5.5838 -1.8107 0)(5.8316 -1.824 0)(5.8316 -1.824 0)(6.0794 -1.8364 0)(6.0794 -1.8364 0)(6.3273 -1.8477 0)(6.3273 -1.8477 0)(6.5752 -1.858 0)(6.5752 -1.858 0)(6.8231 -1.8673 0)(6.8231 -1.8673 0)(7.0711 -1.8756 0)(7.0711 -1.8756 0)(7.3192 -1.8829 0)(7.3192 -1.8829 0)(7.5672 -1.8891 0)(7.5672 -1.8891 0)(7.8153 -1.8942 0)(7.8153 -1.8942 0)(8.0634 -1.8982 0)(8.0634 -1.8982 0)(8.3115 -1.901 0)(8.3115 -1.901 0)(8.5597 -1.9026 0)(8.5597 -1.9026 0)(8.6904 -1.7873 0)(8.6904 -1.7873 0)); } Code:
somePoints { type cloud; axis xyz; points ( (8.4638 -1.6865 0) (8.4638 -1.6865 0) (8.2362 -1.5877 0) (8.2362 -1.5877 0) (8.0081 -1.49 0) (8.0081 -1.49 0) (7.7796 -1.3933 0) (7.7796 -1.3933 0) (7.5506 -1.2976 0) (7.5506 -1.2976 0) (7.3213 -1.203 0) (7.3213 -1.203 0) (7.0915 -1.1093 0) (7.0915 -1.1093 0) (6.8614 -1.0165 0) (6.8614 -1.0165 0) (6.6308 -0.9247 0) (6.6308 -0.9247 0) (6.3999 -0.8338 0) (6.3999 -0.8338 0) (6.1687 -0.7439 0) (6.1687 -0.7439 0) (5.9371 -0.6549 0) (5.9371 -0.6549 0) (5.7051 -0.5668 0) (5.7051 -0.5668 0) (5.4727 -0.4797 0) (5.4727 -0.4797 0) (5.24 -0.3936 0) (5.24 -0.3936 0) (5.007 -0.3084 0) (5.007 -0.3084 0) (4.7735 -0.2243 0) (4.7735 -0.2243 0) (4.5397 -0.1413 0) (4.5397 -0.1413 0) (4.3054 -0.0595 0) (4.3054 -0.0595 0) (4.0708 0.0212 0) (4.0708 0.0212 0) (3.8357 0.1007 0) (3.8357 0.1007 0) (3.6002 0.1788 0) (3.6002 0.1788 0) (3.3642 0.2556 0) (3.3642 0.2556 0) (3.1278 0.3308 0) (3.1278 0.3308 0) (2.8908 0.4044 0) (2.8908 0.4044 0) (2.6533 0.4764 0) (2.6533 0.4764 0) (2.4153 0.5465 0) (2.4153 0.5465 0) (2.1767 0.6146 0) (2.1767 0.6146 0) (1.9375 0.6806 0) (1.9375 0.6806 0) (1.6977 0.7442 0) (1.6977 0.7442 0) (1.4572 0.8054 0) (1.4572 0.8054 0) (1.2161 0.8639 0) (1.2161 0.8639 0) (0.9742 0.9194 0) (0.9742 0.9194 0) (0.7316 0.9716 0) (0.7316 0.9716 0) (0.4883 1.0203 0) (0.4883 1.0203 0) (0.2443 1.0651 0) (0.2443 1.0651 0) (-0.0005 1.1056 0) (-0.0005 1.1056 0) (-0.2461 1.1412 0) (-0.2461 1.1412 0) (-0.4924 1.1715 0) (-0.4924 1.1715 0) (-0.7393 1.1957 0) (-0.7393 1.1957 0) (-0.9868 1.2129 0) (-0.9868 1.2129 0) (-1.2348 1.222 0) (-1.2348 1.222 0) (-1.4829 1.2216 0) (-1.4829 1.2216 0) (-1.7307 1.2097 0) (-1.7307 1.2097 0) (-1.9774 1.1833 0) (-1.9774 1.1833 0) (-2.2213 1.138 0) (-2.2213 1.138 0) (-2.4586 1.0663 0) (-2.4586 1.0663 0) (-2.6799 0.9551 0) (-2.6799 0.9551 0) (-2.8576 0.7842 0) (-2.8576 0.7842 0) (-2.9359 0.552 0) (-2.9359 0.552 0) (-2.8875 0.311 0) (-2.8875 0.311 0) (-2.7523 0.104 0) (-2.7523 0.104 0) (-2.5753 -0.0696 0) (-2.5753 -0.0696 0) (-2.377 -0.2186 0) (-2.377 -0.2186 0) (-2.1662 -0.3495 0) (-2.1662 -0.3495 0) (-1.9474 -0.4663 0) (-1.9474 -0.4663 0) (-1.7228 -0.5718 0) (-1.7228 -0.5718 0) (-1.4941 -0.6679 0) (-1.4941 -0.6679 0) (-1.2621 -0.756 0) (-1.2621 -0.756 0) (-1.0276 -0.8371 0) (-1.0276 -0.8371 0) (-0.791 -0.912 0) (-0.791 -0.912 0) (-0.5528 -0.9815 0) (-0.5528 -0.9815 0) (-0.3133 -1.0461 0) (-0.3133 -1.0461 0) (-0.0725 -1.1062 0) (-0.0725 -1.1062 0) (0.1691 -1.1623 0) (0.1691 -1.1623 0) (0.4117 -1.2147 0) (0.4117 -1.2147 0) (0.6549 -1.2637 0) (0.6549 -1.2637 0) (0.8988 -1.3097 0) (0.8988 -1.3097 0) (1.1432 -1.3527 0) (1.1432 -1.3527 0) (1.388 -1.3932 0) (1.388 -1.3932 0) (1.6332 -1.4312 0) (1.6332 -1.4312 0) (1.8787 -1.4669 0) (1.8787 -1.4669 0) (2.1246 -1.5006 0) (2.1246 -1.5006 0) (2.3707 -1.5322 0) (2.3707 -1.5322 0) (2.617 -1.5621 0) (2.617 -1.5621 0) (2.8636 -1.5902 0) (2.8636 -1.5902 0) (3.1103 -1.6168 0) (3.1103 -1.6168 0) (3.3571 -1.6418 0) (3.3571 -1.6418 0) (3.6041 -1.6654 0) (3.6041 -1.6654 0) (3.8513 -1.6877 0) (3.8513 -1.6877 0) (4.0985 -1.7087 0) (4.0985 -1.7087 0) (4.3459 -1.7285 0) (4.3459 -1.7285 0) (4.5933 -1.7471 0) (4.5933 -1.7471 0) (4.8408 -1.7646 0) (4.8408 -1.7646 0) (5.0884 -1.781 0) (5.0884 -1.781 0) (5.3361 -1.7964 0) (5.3361 -1.7964 0) (5.5838 -1.8107 0) (5.5838 -1.8107 0) (5.8316 -1.824 0) (5.8316 -1.824 0) (6.0794 -1.8364 0) (6.0794 -1.8364 0) (6.3273 -1.8477 0) (6.3273 -1.8477 0) (6.5752 -1.858 0) (6.5752 -1.858 0) (6.8231 -1.8673 0) (6.8231 -1.8673 0) (7.0711 -1.8756 0) (7.0711 -1.8756 0) (7.3192 -1.8829 0) (7.3192 -1.8829 0) (7.5672 -1.8891 0) (7.5672 -1.8891 0) (7.8153 -1.8942 0) (7.8153 -1.8942 0) (8.0634 -1.8982 0) (8.0634 -1.8982 0) (8.3115 -1.901 0) (8.3115 -1.901 0) (8.5597 -1.9026 0) (8.5597 -1.9026 0) (8.6904 -1.7873 0) (8.6904 -1.7873 0) ); } Therefore, at least from this list, there are only 100 valid points. Best regards, Bruno
August 21, 2015, 14:14 |
Diogo Ramalho
Thanks for the quick reply Bruno.
Yes you are right about that long list of code I post above but I'm just starting with OF and there are a lot of things I still need on those files to get a quick memo when I return to them (next time I will remove all the unnecessary lines). As I said above I already got my problem solved and I'm getting all the points I need (not more/less than the ones I input). No more problems with sampleDict. Thanks. Diogo Ramalho |
June 9, 2016, 11:51 |
Dan Pearce
Rep Power: 13 |
Hi all,
I thought I would resurrect this thread as I have been experiencing an unusual problem with the sample utility...I'm using OF 2.4.0 and running the sample dict on the cavitatingFoam/throttle tutorial. The only changes to the base tutorial are in controlDict to specify output as uncompressed ascii (but I don't think that is relevant here). I'm trying to sample the velocity and vapour fraction across 4 lines at different locations. The 4 lines are all vertical across the nozzle (or channel) section approximately at the start, 1/3rd, 2/3rd and end locations and I'm trying to get 100 points. Using the following sample dict gives some interesting results, the first file has 99 points, the second has 74 points, third has 74 points and the last has 100 points. I should also note that the grid is uniform so I'm confused as to why I'm not getting 100 points in all 4 files... Any insight would be appreciated. Note that I have tried different interpolation schemes (same result), tried to vary the start and end xyz location (same result) and requested 50 points instead of 100 (in which case I get 49, 36,36 and 50 data points returned). Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object sampleDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // interpolationScheme cellPoint; setFormat raw; //need to run "foamCalc components U" before in order to have Ux field sets ( line1 { type uniform; axis xyz; start (0.005 0.0002 0.0000); //Line 1 - entrance to nozzle region end (0.005 -0.0002 0.0000); nPoints 100; } line2 { type uniform; axis xyz; start (0.00567 0.0002 0.0000); //Line 2 - 1/3 of nozzle region end (0.00567 -0.0002 0.0000); nPoints 100; } line3 { type uniform; axis xyz; start (0.006318 0.0002 0.0000); //Line 3 - 2/3 of nozzle region end (0.006318 -0.0002 0.0000); nPoints 100; } line4 { type uniform; axis xyz; start (0.007 0.0002 0.0000); //Line 4 - end of nozzle region end (0.007 -0.0002 0.0000); nPoints 100; } ); fields ( Ux alpha.vapour //yPlus //yPlusTwoPhase //yPlusTwoPhase2 ); // ************************************************************************* // |
April 17, 2017, 17:15 |
Jorge Rivas Ordenes
Rep Power: 9 |
Dan,
Did yo manage to make this work? Hope you can help me out with something, can i sample instead or an axis, an area (diferent to any of the patches define in the blockMesh Dictionary)? Thanks, hope you can help me out. |
May 1, 2017, 20:24 |
Harshal Akolekar
Rep Power: 9 |
Any tips on this problem?
May 1, 2017, 21:25 |
Jorge Rivas Ordenes
Rep Power: 9 |
Dear hakolekar:
I manage to solve the sampling of a surface in any region of the domain (is this what you are asking about?) with the following code in the controlDict/function sub-dictionary of my simulation: Code:
cuttingPlane { type surfaces; libs ("libsampling.so"); interpolationScheme cell; writeControl timeStep; writeInterval 10; surfaceFormat raw; fields (U k nut p); surfaces ( inletPlane { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { basePoint (481 400 400); normalVector (1 0 0); } interpolate false; } ); } |
sample, sampledict |
Sample utility bug? For many cloud points in the sampleDict, some are neglected! | brandius | OpenFOAM Post-Processing | 10 | August 22, 2022 09:56 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 6 | November 15, 2014 18:04 |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 0 | February 5, 2010 12:12 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
