Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Derivative of velocity and mean velocity
Old   January 30, 2014, 11:18
Default Derivative of velocity and mean velocity
Huynh Phong Thanh
hiuluom is on a distinguished road
Dear all,
I would like to calculate \frac{\partial^2 \langle u_i\rangle}{\partial x_j^2} and \frac{\partial \langle u_i\rangle}{\partial x_j}, <u> its means umean. At first, I want to test foamCalc and foamCalcEx with div(u) or grad(u), but it has error. Can anyone help me check it?
Selecting calcType div
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : foamCalc div U
Date   : Jan 30 2014
Time   : 23:03:37
Host   : "compeng"
PID    : 7276
Case   : /home/huynh/OpenFOAM/huynh-2.1.1/run/pitzDaily
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Time = 0
    Reading U
    Calculating divU
--> FOAM Warning :
--> FOAM FATAL IO ERROR:
keyword div(U) is undefined in dictionary "/home/huynh/OpenFOAM/huynh-2.1.1/run/pitzDaily/system/fvSchemes::divSchemes"
file: /home/huynh/OpenFOAM/huynh-2.1.1/run/pitzDaily/system/fvSchemes::divSchemes from line 36 to line 45.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 400.
Time = 0.01
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.02
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.03
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.04
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.05
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.06
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.07
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.08
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.09
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.1
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.10001
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.11
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.12
    Reading U
    Calculating divU
--> FOAM Warning :
Time = 0.13
    Reading U
    Calculating divU
--> FOAM Warning :
End
Thank you.
Best regards,
Thanh.
hiuluom is offline   Reply With Quote
Old   May 29, 2015, 23:42
Huynh Phong Thanh
The problem above were solved at link:
http://www.cfd-online.com/Forums/ope...-parafoam.html
