Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to plot with gnuplot?
Old   May 29, 2015, 13:26
Default How to plot with gnuplot?
miri miri
miri is on a distinguished road
Hello all,
I want to compare experimental data with my results from the simulation using gnuplot.
Because my simulation is about a turbulent jet-flame, I want to plot for example the velocity or temperature over a radial profile.
It should looks like that:
It would be very helpful, if somebody could give me a step-by-step solution, how something like that is done.
I'm thankful for every advice.
kind regards.
miri is offline   Reply With Quote
Old   June 4, 2015, 08:58
roadRunner is on a distinguished road
there is a tool called sample, which you should use to get xy plot of your data.
you need a sampleDict, which you can find in the openFoam source. All is explained inside this dict.
After that, you can create gnuplot dict to plot the data located in .xy file you created with sample. http://www.gnuplotting.org/plotting-data/
beep-beep
roadRunner is offline   Reply With Quote
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 15:40
to plot Mach contour using GNUPLOT killtimm Main CFD Forum 2 December 28, 2009 11:15
how to plot contour or vector with "GNUPLOT" ztdep Main CFD Forum 2 June 19, 2006 12:26
how to plot isotherms in gnuplot? sivasamy Main CFD Forum 0 December 19, 2005 01:26
To plot a grid using Gnuplot Jim Main CFD Forum 5 September 3, 2004 16:32
