Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Heat report
Old   July 13, 2015, 06:16
Default Heat report
Jorge Lobera
jlobera is on a distinguished road
Hi all,
I'm using OpenFoam to simulate the air flow through a tower with buoyantSimpleFoam solver. I have used externalWallHeatFluxTemperature BC to simulate the heat losses by convection across the tower wall.
Now I want to know the heat dissipation in every surface with convection. I have been loking for some utility but I haven’t found. I’m especially interested knowing the heat using PyFoamPlotWatcher.
Someone knows if there is any expression to include the heat in the customRegExp file? Or someone knows how to do the post-processing of the heat through a wall?
Thanks all
jlobera is offline   Reply With Quote
Old   July 13, 2015, 10:54
Alex
zfaraday will become famous soon enough
what about wallHeatFlux utility provided with OF? Check it out!
Besides that you can use some function objects in your controlDict file in order to compute the same heat fluxes and plot your results with gnuplot.
Hope it helps,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   July 14, 2015, 03:37
Jorge Lobera
Thanks Alex,
I think wallHeatFlux will be a good option.
The problem with gnuplot is I can't use any expression because outside the wall there isn’t mail so I can´t use a gradient or any other expression.
If someone knows any solution it will be welcome.
Thanks;
Old   July 14, 2015, 05:58
Alex
Hi Jorge,
I'm not sure if I get your problem about using gnuplot... However, I recomend you to use the function object attached below. Copy it and paste it to your controlDict file. It computes the heat by convection at every patch of your geometry. It only works if you have swak4foam installed, I hope you have it...
functions
    heat_air_patches
        type patchExpression;
        outputControlMode timeStep;
        outputInterval 1;
        patches (".*");
        region air;              //only if it is a multi region case
        accumulations ( sum );
        verbose true;
        aliases { alpha thermo:alpha; }
	expression "alpha*snGrad(h)*area()";
libs (
    "libsimpleFunctionObjects.so"
    "libsimpleSwakFunctionObjects.so"
    "libswakFunctionObjects.so"
Hope it helps,
Alex
heat exchange, post processing, pyfoam customregexp, pyfoamplotwatcher.py
Radiation interface hinca CFX 15 January 26, 2014 17:11
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 04:07
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
CFX Heat Transfer RJamison CFX 0 July 24, 2008 12:11
