Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
General understanding of postprocessing in paraFoam
Old   October 15, 2015, 05:38
Default General understanding of postprocessing in paraFoam
Gerrit is on a distinguished road
Hi everyone,
I want to get values out of my simulations for a mesh-independence study. No problem:
1. Insert a slice
2. Insert a Filter "Integrate variables"
3. Attribute "Cell Data"
1. As far as I understood, I have to divide the value by the area at that position, is that correct?
2. The pressure, that is defined in 0/p and given in paraFoam in the filter e.g. is the relative static pressure, right?
3. Do I have to multiply that pressure with density to receive the correct pressure?
Sorry for these basic questions, but I do not want to make stupid mistakes!
Gerrit is offline   Reply With Quote
Old   October 16, 2015, 05:10
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Let me respond to your questions:
1. If you want to have the average over the area: yes. You can actually do this by using the calculator filter after the integrate variables filter (there should be a variable "Area")
2. If you are running an incompressible solver: yes. You can also find it in the dimensions of your 0/p file. If it reads [0 2 -2 0 0 0 0] you have kinematic pressure (pressure divided by density). If it reads [1 -1 -2 0 0 0 0] you have absolute pressure. OpenFOAM uses relative pressure in incompressible cases, but absolute pressure in compressible cases.
3. (Like in 2.): yes if incompressible
Regards,
Tom
tomf is offline   Reply With Quote
Old   October 20, 2015, 02:08
Hi Tom,
thank you very much for your reply! It's nice to know, that I was on the right path
[OpenFOAM] How to use paraFoam on a cluster andreas ParaView 1 March 6, 2013 17:11
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 05:20
Dynamic_cast failing while postprocessing with paraFoam gschaider OpenFOAM Bugs 3 August 20, 2010 16:37
[OpenFOAM] Install paraFoam on Windows for postprocessing melanie ParaView 11 March 13, 2010 17:44
[OpenFOAM] Parafoam basic questions qtian ParaView 0 July 20, 2007 11:52
