December 7, 2015, 04:07 |
Failed to run particleTracks
Yuzheng
Rep Power: 10 |
I try to display particle tracks in a DPMFoam case. But there is something wrong as below.
Time = 0.98 Reading particle positions Constructing tracks Time = 0.99 Reading particle positions Constructing tracks Time = 1 Reading particle positions Constructing tracks #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Segmentation fault (core dumped) |
March 27, 2019, 10:57 |
#2 | |
spike
Rep Power: 7 |
Do I have the same problem when doing postprocessing executing particleTracks, you could already solve it? you could post the solution please. thank you |
June 27, 2019, 13:31 |
Eduardo Cruz
Rep Power: 7 |
I also have the same problem. Any solution?
Help is appreciated. ECruz |
parallel run is slower than serial run (pimpleFoam) !!! | mechy | OpenFOAM | 18 | August 17, 2016 17:19 |
Flow simulation in wind tunnel | mukut | OpenFOAM | 15 | September 11, 2013 22:43 |
Run Functions Failed - Attempted MPI Cluster | LordLoss | OpenFOAM Pre-Processing | 0 | August 14, 2013 07:43 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
connect failed with errno%3d113 | wedsall | OpenFOAM Running, Solving & CFD | 2 | November 3, 2008 04:17 |
