Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Plot part of mesh on surface elevation filter
Old   January 14, 2016, 18:26
Default Plot part of mesh on surface elevation filter
Maxim Van Zonhoven
MaximVZ is on a distinguished road
Recently I have been trying to simulate a wave field past a fixed cylinder.
I would like to give the surface elevation on a figure with the cylinder also clearly visible.
By applying a contour and calculator filter I succeeded in plotting the surface elevation itself (attach.).
Is it possible to add the actual cylinder in this figure?
It seems I can not just make the internal mesh invisible because my filters rely on this part of the mesh to be visible.
Thanks in advance.
Regards,
Maxim
MaximVZ is offline   Reply With Quote
Old   January 15, 2016, 13:34
Davi Barreira
davibarreira is on a distinguished road
I assume you are using Paraview. In the same file that you are working in paraview, press the "open" and select your case file again (your .foam file in the case folder). Once you do that, you will have two identical files, but now you may superpose them. So in one of them you do all your filtering to show the wave, and in the other you leave it be, that way you will see the cylinder.
(there are many different ways to do this)
davibarreira is offline   Reply With Quote
Old   January 15, 2016, 18:23
Maxim Van Zonhoven
This works very well.
Thank you very much!
Maxim
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
