Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
pyFoamTimelinePlot.py giving error: IndexError: list index out of range
Old   January 29, 2016, 10:27
Default pyFoamTimelinePlot.py giving error: IndexError: list index out of range
ArielJ
arieljeds is on a distinguished road
Hi everyone,
I am trying to use probes and functionObjects for the first time (still pretty new to openfoam) and then I want to use pyFoamTimelinePlot.py to convert the files to csv and plot the data.
First of all, when I look into the postProcessing directory, the function objects and probes (from system/probeDict and running probeLocations) seem to have done what they're supposed to do but when I run the following command:
pyFoamTimelinePlot.py . --fields=magU --dir=postProcessing/probes/0/ --basic-mode=lines --csv=magU.csv
I get the following output:
Traceback (most recent call last):
  File "/usr/local/bin/pyFoamTimelinePlot.py", line 5, in <module>
    pkg_resources.run_script('PyFoam==0.6.5', 'pyFoamTimelinePlot.py')
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 499, in run_script
    self.require(requires)[0].run_script(script_name, ns)
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 1235, in run_script
    execfile(script_filename, namespace, namespace)
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/EGG-INFO/scripts/pyFoamTimelinePlot.py", line 5, in <module>
    TimelinePlot()
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Applications/TimelinePlot.py", line 34, in __init__
    **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Applications/PyFoamApplication.py", line 424, in __init__
    result=self.run()
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Applications/TimelinePlot.py", line 239, in run
    writeTime=self.opts.writeTime)
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/RunDictionary/TimelineDirectory.py", line 53, in __init__
    self.usedTime=self.writeTimes[0]
I get the same output when I run
pyFoamTimelinePlot.py . --fields=magU --dir=postProcessing/probes/0/ --basic-mode=lines | gnuplot
I found some advice from 2008 which seems to not be relevant any more but haven't seen anything else useful.
Does anyone have experience with this issue who can offer some help?
arieljeds is offline   Reply With Quote
index of range, openfoam 2.3.0, pyfoam, pyfoamtimelineplot.py, ubuntu 12.04
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
AMI memory leak? MichiB OpenFOAM Programming & Development 14 August 1, 2015 18:18
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 10:45
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
