Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
unsigned transforms detected
Like Tree1Likes
  • 1 Post By Marc10
Old   November 8, 2011, 20:45
Question unsigned transforms detected
Adam
Smed is on a distinguished road
I have two versions of a single geometry; one is meshed uniformly, the other is non-uniform. Both of these meshes pass the checkMesh. When I view the uniform mesh with paraView, it works just fine. However, when I view the non-uniform mesh, paraView crashes and gives this error:
--> FOAM FATAL ERROR:
More than six unsigned transforms detected:
6(((0 0 0) (0.980405 -0.000769865 0.196992 0.000385611 0.999998 0.00198896 -0.196993 -0.00187402 0.980403) 1) ((0 0 0) (0.980785 0 0.19509 0 1 0 -0.19509 0 0.980785) 1) ((0 0 0) (0.980405 0.000769865 0.196992 -0.000385611 0.999998 -0.00198896 -0.196993 0.00187402 0.980403) 1) ((0 0 0) (0.980786 -0.000760095 0.195087 0.000760071 1 7.49816e-05 -0.195087 7.47395e-05 0.980786) 1) ((0 0 0) (0.980786 0.000760095 0.195087 -0.000760071 1 -7.49816e-05 -0.195087 -7.47395e-05 0.980786) 1) ((0 0 0) (0.980785 -0.000637449 0.195088 0.000637449 1 6.27799e-05 -0.195088 6.27852e-05 0.980786) 1))
From function void Foam::globalIndexAndTransform::determineTransforms ()
in file primitives/globalIndexAndTransform/globalIndexAndTransform.C at line 225.
FOAM exiting
Does anyone know what might cause this?
Smed is offline   Reply With Quote
Old   November 23, 2011, 04:56
Marc-Florian Uth
Marc10 is on a distinguished road
Hi!
I have a problem that gives me the same error message. It happens for a certain mesh when I start mdInitialise with one or more cyclic boundaries. If I set all boundaries to walls, it works.
Does anyone know what causes this error message?
Thank you!
marc
Marc10 is offline   Reply With Quote
Old   November 23, 2011, 06:00
Marc-Florian Uth
I could solve my problem.
There were some unordered cyclics. I fixed that by using createPatch to build the cyclic boundaries.
Old   October 7, 2012, 12:32
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Hi Marc,
I am also having the same problem, could you please explain.
what we need to do?
how can we create the createPatch?
Thanks,
Siva
sivakumar is offline   Reply With Quote
Old   October 8, 2012, 08:37
Marc-Florian Uth
Hi Siva!
The problem were unordered cyclic patches. That sometimes happens, when you create these patches directly in the blockmeshdict.
Instead you could try to build the mesh with normal patches (type patch). Afterwards you can use createPatch together with a createpatchdict to replace the patch types with cyclic patches and couple the cells correctly.
I hope that helps. Feel free to write me again.
marc
Luttappy likes this.
Old   July 17, 2014, 12:18
Julien
Djub is on a distinguished road
Hi!
I have the same kind of problem, with the same error message ("More than six unsigned transforms detected"). But I do NOT have any cyclic patch !
My blockMeshDict has the types patch , symmetryPlane and wall only .
And my boundary conditions are types timeVaryingMappedFixedValue , inletOutlet , symmetryPlane and fixedValue .
I don't understand what I do wrong ? ! ? The problem occurs when I launch snappyHexMesh in parallel. Does anybody have a solution ?
Djub is offline   Reply With Quote
Old   June 17, 2016, 11:09
rana
ranasa is on a distinguished road
Dear friends,
greetings
could any one find a clue for the error?
i import a simple 2D case, sketched in Gambit. with side walls as cyclic BC, i use createPatch and the case runs correctly, but paraView crushes immediately as i ask for volume fields
look forward to any helpful comment
ranasa is offline   Reply With Quote
Old   June 17, 2016, 11:27
rana
and the error is as the same as for Smed's case
6(((-0.42 0 0) (1 0 0 0 1 0 0 0 1) 0) ((-0.42 -0.369148 8.67362e-19) (1 0 0 0 1 0 0 0 1) 0) ((-0.42 0.369148 8.67362e-19) (1 0 0 0 1 0 0 0 1) 0) ((-0.42 -0.349194 -8.67362e-19) (1 0 0 0 1 0 0 0 1) 0) ((-0.42 0.349194 8.67362e-19) (1 0 0 0 1 0 0 0 1) 0) ((-0.42 0.19954 0) (1 0 0 0 1 0 0 0 1) 0))
in file primitives/globalIndexAndTransform/globalIndexAndTransform.C at line 187.
FOAM exiting
Divergence detected in AMG solver: ads-0 Patrino FLUENT 6 May 12, 2022 03:11
Error: Divergence detected in AMG solver siri FLUENT 8 March 12, 2018 17:08
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
