Home > Forums > Visualization & Post-Processing Software > ParaView
[General] How can I use python script to generate animation from 2000 frames of vtk datasets
Like Tree1Likes
  • 1 Post By Flowkersma
Old   March 7, 2016, 17:40
Default How can I use python script to generate animation from 2000 frames of vtk datasets
Lieyu Shi
LieyuShi is on a distinguished road
I'm a beginner in Paraview. I just generated 2000 frames of vtk data for fluid simulation. I have separately uploaded files in Paraview and was able to see the image. I have two concerns
1. How can I use shell script to automatically generate animation from these datasets? Can Paraview achieve that with some piece of python code?
2. If the answer for above is no, can I write a script to automatically upload and save screenshots of each dataset respectively? I could only manually save screenshots from GUI.
Can somebody kindly help me with that? I was still learning Python script and searched materials online for that. Attached is one of my manually generated figure for fluid.
LieyuShi is offline   Reply With Quote
Old   March 10, 2016, 09:02
Mikko
Flowkersma is on a distinguished road
I think the easiest way is to rename the files such that they are foo0001.vtk, foo0002.vtk, foo0003.vtk, ..., foo2000.vtk and move all files to same directory. Then from ParaView GUI press Open and browse to the directory and you should see a filename called foo..vtk which loads all the timesteps. Now, you should be able to create an animation by pressing "Save Animation".
Regards,
Mikko
Originally Posted by LieyuShi View Post
LieyuShi likes this.
Flowkersma is offline   Reply With Quote
Old   March 10, 2016, 13:28
Lieyu Shi
Thanks for your kind reply. It really works!!! I never image it can that easy to create an animation... Actually I spent a long time writing script and trying to make it work... Thanks greatly
Old   March 10, 2016, 13:37
Lieyu Shi
Thanks greatly. I never imagine it to be this easy. Actually I spent days in writing the script file to manage load, transformation and save.. Thanks man
Best
Lieyu
Originally Posted by Flowkersma View Post
Regards,
Mikko
[General] Generating isosurface from vtk file with python script Leios ParaView 1 March 26, 2018 12:33
[General] Paraview.simple python module and loading legacy vtk file timeseries awa5114 ParaView 2 July 17, 2017 08:40
[OpenFOAM] Python script to export animation images mahyarv14 ParaView 10 August 16, 2014 11:11
[General] VTK API: Working with values inside the python shell Thoma ParaView 4 January 10, 2013 14:35
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 09:36
