[OpenFOAM] How to calculate mass flow rate through arbitrary rectangle plane in paraview |
March 10, 2016, 02:16 |
Manoj
Rep Power: 12 |
Hi All,
I am trying to calculate mass flow rate at 12 HVAC vents opening. These openings are not defined as patch or face. They are interior of the domain. I want to define plane/rectangle of a give size at these opening locations to calculate the mass flow rate through them. But when I create a plane in paraview using sources > plane, the plane doesn't have nay data field - U or p. Please help me to calculate mass flow rate at arbitrary plane in the domain. When I use slice or cut plane, it cuts through the whole domain, which I don't want. Regards, Manoj |
March 11, 2016, 05:04 |
If you want to use the plane from sources, you need to do resampleWithDataSet. I typically use the following sequence of filters: Slice>Connectivity>threshold on the "regionID" (see example images) Regards, Tom |
March 11, 2016, 06:28 |
Thomas Oliveira
Rep Power: 12 |
March 14, 2016, 10:39 |
#4 | |
Manoj
Rep Power: 12 |
When I use sequence of filters: Slice>Connectivity .. I get just one region ID - 0, as in the attached snapshot. How to use the threshold then. Sorry for my ignorance.. Regards, Manoj |
March 14, 2016, 10:41 |
Manoj
Rep Power: 12 |
March 17, 2016, 02:51 |
#6 | |
Manoj
Rep Power: 12 |
keyword sourceName is undefined in dictionary "/home/manoj/trial/vent/system/controlDict.functions.new_plane" Code:
functions { new_plane { type faceSource; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl outputTime; log true; valueOutput true; source sampledSurface; sampledSurfaceDict { type sampledTriSurfaceMesh; surface opening.stl; source cells; // What to sample: cells (nearest cell) // insideCells (only triangles inside cell) // boundaryFaces (nearest boundary face) interpolate true; } operation areaAverage; fields ( U ); } } Code:
functions { #include "volFlowRateSurface" } Regards, Manoj |
March 18, 2016, 12:27 |
#7 | |
In that case there is no possibility for the threshold filter. I had assumed you would have some distinct regions for each opening, maybe you could make a clear sketch of what you are trying to do. Regards, Tom |
April 1, 2016, 07:14 |
#8 | |
Thomas Oliveira
Rep Power: 12 |
Check this post, which offers another way of defining a (infinite) plane that may be useful to you : http://www.cfd-online.com/Forums/ope...tml#post581774 Regarding the error your received, have you tried inserting the keyword sourceName inside the new_plane dictionary, like below? That is what the error message says. Code:
functions { new_plane { type faceSource; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl outputTime; log true; valueOutput true; source sampledSurface; sourceName anyNameYouLike; ... Thomas |
Specify mass flow rate for periodic boundary conditions in channel flow | lion1990 | OpenFOAM Running, Solving & CFD | 1 | July 9, 2018 17:46 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Periodic channel flow with time dependent mass flow rate | QBeast | FLUENT | 3 | May 10, 2013 13:14 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 17:57 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 10:44 |
