Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Writing c++ for loops in sampleDict file
Like Tree1Likes
  • 1 Post By arieljeds
Old   April 14, 2016, 07:43
Default Writing c++ for loops in sampleDict file
ArielJ
arieljeds is on a distinguished road
Hi there,
I'm trying to write my sampleDict so that I can easily adjust the location of probes by changing one line (say, the diameter for a cylinder). I want to write a for loop that will loop through a theta value from 0 to 2*pi in steps of pi/16 (32 probes), and calculate the location of the probes. The bit of code I have so far is:
    r      -3.05;
    //r2     -3.05;
    pi	     #calc "4.0*atan(1.000)";
    p1     #calc "$r2*cos($pi/16)";
    n		32;
    z        -1.0;
    dtheta 	#calc "$pi/8";
    theta[$n]   {};
    theta[0] = 0;
    for (i = 1; i == n; i++)
    	theta[$i] = theta[$i - ] + $dtheta;
    	x[$i] = $r * cos(theta[$i]);
    	y[$i] = $r * sin(theta[$i]);
And then following this, I planned to set up the points like this:
cylinderProbes
        type    cloud;
        axis    xyz;
        points
            ( $x[0]   $y[0]    $z )
            ( $x[1]   $y[1]    $z )
            ..... etc.....
This is, probably obviously, not working. I did something similar in my blockMeshDict, which worked out fine but now I'm getting errors (lots and lots of errors...) I know that I should be using C++ but I also know that Openfoam isn't quite C++, so I made some guesses about the syntax here. Can anyone offer some advice on how to do this??
Thanks in advance!
Bosen likes this.
arieljeds is offline   Reply With Quote
c++, for loop, sampledict
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
