Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Sampled data in a single file (probes)
Like Tree1Likes
  • 1 Post By akidess
Old   May 20, 2016, 07:03
Default Sampled data in a single file (probes)
Jambne is on a distinguished road
Hello to everyone,
I'm using the probe function to sample the pressure in a bunch of points. The problem is that every time that I stop and re-start the simulation OpenFoam creates a new folder with the log file (p) inside, starting from the latest time (e.g. postProcessing->Probes-->0, 0.2, 0.6, etc.).
Is it possible to keep all the sampled data in a single file?
Thank you!
Jambne is offline   Reply With Quote
Old   May 20, 2016, 07:12
akidess's Avatar
Anton Kidess
I'd just cat them afterwards.
cat postProcessing/probes/*/p >> p_all.dat
bigphil likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   May 20, 2016, 09:15
It kinda works but it doesn't attach the files in the correct chronological order. Any suggestion?
Old   May 20, 2016, 10:15
Ok my mistake, It works correctly and the order is right!
Thank you so much.
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
