[OpenFOAM] Trouble installing ParaView from source |
June 15, 2016, 05:39 |
Rep Power: 10 |
Dear all,
I'm fighting with ParaView wiki in order to install it from source... I have Ubuntu 15.10 and want to install ParaView 3.12, so I need to compile it from source... This is the wiki I'm following: http://www.paraview.org/Wiki/index.p...ll&oldid=46445 I can arrive without problems to "configure ParaView with cmake" but then it make no sense anymore for me...It is told this: "Use ccmake (Curses CMake GUI) from the CMake installed location. CCMake is a Curses based GUI for CMake. To run it go to the build directory and specify as an argument the src directory." What does this mean? There is some command after this few lines but they call a folder I haven't created... I really don't know what to do...Can please someone help me?
Omnia per ipsum facta sunt, et sine ipso factum est nihil, quod factum est |
June 15, 2016, 09:41 |
Install Debian Package instead
Suryansh D Kumar
Rep Power: 9 |
Hi Jack
It is indeed a very tedious and time consuming task to install paraview from source. I would suggest that you install it from the debian packages available at the OpenFoam website's download page sudo dpkg -i <packageName.deb> can be used to install debian packages on any linux platform. You do not need to install it from source. I installed both OpenFoam and paraview using these packages, and I am using Linux Mint 17.2 |
June 15, 2016, 10:22 |
Rep Power: 10 |
I also tried to follow the instructions on OF site for compiling version 2.2.1 (the one I use) and for the related third party (ParaView 3.12) but I have this error...
-- Configuring development install... -- Configuring incomplete, errors occurred! See also "/home/openfoam/OpenFOAM/ThirdParty-2.2.1/build/linux64Gcc/paraview-3.12.0/CMakeFiles/CMakeOutput.log". See also "/home/openfoam/OpenFOAM/ThirdParty-2.2.1/build/linux64Gcc/paraview-3.12.0/CMakeFiles/CMakeError.log". Starting make make: *** No targets specified and no makefile found. Stop. Command exited with non-zero status 2 0.00user 0.00system 0:00.00elapsed 0%CPU (0avgtext+0avgdata 2412maxresident)k 0inputs+0outputs (0major+141minor)pagefaults 0swaps Done make Installing ParaView to /home/openfoam/OpenFOAM/ThirdParty-2.2.1/platforms/linux64Gcc/paraview-3.12.0 make: *** No rule to make target 'install'. Stop. --- Installation complete for paraview-3.12.0 Set environment variables: export ParaView_DIR=/home/openfoam/OpenFOAM/ThirdParty-2.2.1/platforms/linux64Gcc/paraview-3.12.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.12 --- Done
June 15, 2016, 10:26 |
Rep Power: 10 |
I'm following this guide: http://openfoam.org/download/2-2-1-source/
June 15, 2016, 10:32 |
Suryansh D Kumar
Rep Power: 9 |
These are the latest versions of paraview and openFoam for 32bit and 64bit both. You can use them.
openfoam.org/download/ubuntu/dists/trusty/main/binary-i386/openfoam30_1-1_i386.deb openfoam.org/download/ubuntu/dists/trusty/main/binary-i386/paraviewopenfoam44_0-1_i386.deb openfoam.org/download/ubuntu/dists/trusty/main/binary-amd64/openfoam30_1-1_amd64.deb openfoam.org/download/ubuntu/dists/trusty/main/binary-amd64/paraviewopenfoam44_0-1_amd64.deb openfoam.org/download/ubuntu/dists/wily/main/binary-i386/openfoam30_1-1_i386.deb openfoam.org/download/ubuntu/dists/wily/main/binary-i386/paraviewopenfoam44_0-1_i386.deb openfoam.org/download/ubuntu/dists/wily/main/binary-amd64/openfoam30_1-1_amd64.deb openfoam.org/download/ubuntu/dists/wily/main/binary-amd64/paraviewopenfoam44_0-1_amd64.deb These are the packages of version 2.2.1, which you are looking for. Found them here http://openfoam.org/download/2-2-1-ubuntu/ openfoam.org/download/ubuntu/dists/precise/main/binary-amd64/openfoam221_0-1_amd64.deb openfoam.org/download/ubuntu/dists/precise/main/binary-amd64/paraviewopenfoam3120_0-1_amd64.deb openfoam.org/download/ubuntu/dists/precise/main/binary-i386/openfoam221_0-1_i386.deb openfoam.org/download/ubuntu/dists/precise/main/binary-i386/paraviewopenfoam3120_0-1_i386.deb openfoam.org/download/ubuntu/dists/quantal/main/binary-amd64/openfoam221_0-1_amd64.deb openfoam.org/download/ubuntu/dists/quantal/main/binary-amd64/paraviewopenfoam3120_0-1_amd64.deb openfoam.org/download/ubuntu/dists/quantal/main/binary-i386/openfoam221_0-1_i386.deb openfoam.org/download/ubuntu/dists/quantal/main/binary-i386/paraviewopenfoam3120_0-1_i386.deb openfoam.org/download/ubuntu/dists/raring/main/binary-amd64/openfoam221_0-1_amd64.deb openfoam.org/download/ubuntu/dists/raring/main/binary-amd64/paraviewopenfoam3120_0-1_amd64.deb openfoam.org/download/ubuntu/dists/raring/main/binary-i386/openfoam221_0-1_i386.deb openfoam.org/download/ubuntu/dists/raring/main/binary-i386/paraviewopenfoam3120_0-1_i386.deb You can go to the download for ubuntu page for any Openfoam version and it will have the links for the packages down in the page. Hope this helps. It is much much faster than installing from source, took me less than a minute |
build, cmake, paraview 3.12, source code |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
[swak4Foam] problem on installing swak4Foam | navid2 | OpenFOAM Community Contributions | 2 | May 30, 2012 04:32 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
