How to plot surface elevation vs time in paraview4? |
January 24, 2017, 14:18 |
Ioanna
Rep Power: 9 |
I am using interFOAM to run a dam break case. I am post-processing the results with paraview4 and trying to get a plot of water elevation versus time. Everything I have tried seems to give me wrong results. Any ideas? Thank you, Ioanna |
February 22, 2017, 14:51 |
#2 | |
kasra karimi
Rep Power: 10 |
you can pick a section which you want to see the free surface fluctuation in that, then you should use "plot over line" option from filters>data analysis (be sure that the line covers all of the vertical length on your domain), then chose the "integrated variables", and in the final step chose "plot selection over time " |
dam break results, paraview 4.0.1, plot surface, plot vs time |
Elastic or Plastic Deformations in OpenFOAM | NickolasPl | OpenFOAM Pre-Processing | 36 | September 23, 2023 08:22 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
