Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Equidistant points on sample surface?
Old   August 22, 2016, 04:04
Default Equidistant points on sample surface?
HenningW is on a distinguished road
Hello everyone,
I almost feel slightly embarrassed to ask this because it seems so simple:
Is it possible to sample a plane (in control dict or sampleDict) with equidistant probing points (e.g. you give the amount of points in the 2 directions)? And if it is possible, how is it done?
I want to use the sampled planes as inlet conditions for another case, but when i use
        cuttingPlane
                type            surfaces;
                functionObjectLibs
                        "libsampling.so"
                outputControl   timeStep;
                outputInterval  4;
                surfaceFormat   foamFile;
                fields
                        p U k epsilon
                interpolationScheme cellPoint;
                surfaces
                            yNormal_OF
                                type cuttingPlane;
                                planeType pointAndNormal;
                                pointAndNormalDict
                                    basePoint (0.5 0 0);
                                    normalVector (1 0 0);
                                interpolate true;
in my controlDict, the meshes have a varying number of points, since I have a dynamic mesh and this messes up the inlet-boundary condition, since it seems to require the same amout of points at the same spot. As least from what I see it does not read the points for each time step but a constant one at the beginning.
So how can I get the points at the same spot at all times? Or how can I convert the results the easiest way? By the way, the position and size of the cutting area remains the same, its just the points within that cange.
Any help is appreciated,
Henning
HenningW is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
sample from curved surface Smed OpenFOAM Post-Processing 14 October 21, 2015 00:02
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 01:44
How to input surface value using sample nygbook OpenFOAM Post-Processing 3 June 9, 2012 22:45
