Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
probe wallShearStress
Old   October 18, 2016, 09:51
Default probe wallShearStress
baS
baS is on a distinguished road
Hi Foamers,
I want to calculate the friction velocity u* = sqrt(tau_w/rho) on several points on a plate with openFoam 4.x. For this reason I want to calculate the shear stress and the density at the wall.
The output should be in the "postProcess"-format (coordinate / value) and not in the time-Folder.
I tried the following functions so far:
1. rhoSimpleFoam -postProcess -func wallShearStress
-> calculates wallShearStress in the time folder and the min/max-Values in the postProcess-Folder. Do I need an extra wallShearStress-file for defining the probe-locations?
2.
rhoSimpleFoam -postProcess -func probes
with the "probes"-file:
type probes;
setFormat raw;
fields
wallShearStress
probeLocations(
( 0 0 0)
-> no files are written in postProcessing-Folder (but it works for fields(U,k))
Any solutions?
Thanks for your Help!
Sebastian
baS is offline   Reply With Quote
Old   August 7, 2018, 14:25
gu1
Guilherme
gu1 is on a distinguished road
Originally Posted by baS View Post
Hi Foamers,
2.
type probes;
setFormat raw;
fields
wallShearStress
probeLocations(
( 0 0 0)
Any solutions?
Sebastian
Did you find the solution? I need to monitor the wallShearStress in the wall throughout the simulation to contextualize the convergence of a turbulent case.
gu1 is offline   Reply With Quote
postprocess, wallshearstress
Using Probe for part of a patch ndr OpenFOAM Running, Solving & CFD 7 April 4, 2019 06:26
Empty Probe File - Probes not working rvmedina20 OpenFOAM Post-Processing 3 May 11, 2016 19:36
why does 'sample' do this? wallShearStress question CHARLES OpenFOAM Post-Processing 0 August 7, 2013 19:30
wallShearStress VS wallGradU bigrock OpenFOAM Post-Processing 0 July 2, 2013 05:54
Line Probe Smoothing badger1 STAR-CCM+ 1 May 21, 2013 22:36
