Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] paraFoam aborts once dsmc - lagrangian is viewed and results played
Old   January 26, 2017, 14:31
Unhappy paraFoam aborts once dsmc - lagrangian is viewed and results played
James C
jpaolo is on a distinguished road
I have modified the dsmcFoam tutorial freeSpaceStream and have added my own geometry. After several errors on my blockMeshdict I manage to get it to work and to run and solve, once dsmcFoam command was entered. But once I enter paraview and want to view the movement of the particles by selecting dsmc - lagrangian option instead of the internal mesh (assuming all volume fields and lagrangian fields are selected) and once I press play to see the particles move, paraview crashes and shows this error message.
I have also changed the write precision from 20, to 40, and then 60, then 100 and finally 1000 but error still persists and so I changed the the writeFormat to 'binary' instead of ascii. But error still appears, and I have also increased the write precision whilst writeFormat is binary. Please help!
..........................:~/OpenFOAM/eg634172-v1606+/run/vacuuminterrupter/vi1$ paraFoam
Created temporary 'vi1.OpenFOAM'
--> FOAM FATAL ERROR:
position (-0.002919220345468427017104895426768962352070957422 2564697265625 0.096747748850443737733684201884898357093334197998 046875 0.005000000000000001838806884535415520076639950275 421142578125)
for requested cell 20370
If this is a restart or reconstruction/decomposition etc. it is likely that the write precision is not sufficient.
Either increase 'writePrecision' or set 'writeFormat' to 'binary'
From function void Foam:article::initCellFacePt()
in file /home/eg634172/OpenFOAM/OpenFOAM-v1606+/src/lagrangian/basic/lnInclude/particleI.H at line 718.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::Cloud<Foam:assiveParticle>::initCloud(bool ) at ??:?
#3 Foam::vtkPVFoam::lagrangianVTKMesh(Foam::fvMesh const&, Foam::word const&) at ??:?
#4 Foam::vtkPVFoam::convertMeshLagrangian(vtkMultiBlo ckDataSet*, int&) at ??:?
#5 Foam::vtkPVFoam::Update(vtkMultiBlockDataSet*, vtkMultiBlockDataSet*) at ??:?
#6 vtkPVFoamReader::RequestData(vtkInformation*, vtkInformationVector**, vtkInformationVector*) at ??:?
#7 vtkExecutive::CallAlgorithm(vtkInformation*, int, vtkInformationVector**, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#8 vtkDemandDrivenPipeline::ExecuteData(vtkInformatio n*, vtkInformationVector**, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#9 vtkCompositeDataPipeline::ExecuteData(vtkInformati on*, vtkInformationVector**, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#10 vtkDemandDrivenPipeline::ProcessRequest(vtkInforma tion*, vtkInformationVector**, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#11 vtkStreamingDemandDrivenPipeline::ProcessRequest(v tkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#12 vtkCompositeDataPipeline::ForwardUpstream(vtkInfor mation*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#13 vtkDemandDrivenPipeline::ProcessRequest(vtkInforma tion*, vtkInformationVector**, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#14 vtkStreamingDemandDrivenPipeline::ProcessRequest(v tkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#15 vtkCompositeDataPipeline::ForwardUpstream(vtkInfor mation*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#16 vtkDemandDrivenPipeline::ProcessRequest(vtkInforma tion*, vtkInformationVector**, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#17 vtkStreamingDemandDrivenPipeline::ProcessRequest(v tkInformation*, vtkInformationVector**, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#18 vtkDemandDrivenPipeline::UpdateData(int) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#19 vtkStreamingDemandDrivenPipeline::Update(int) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonExecutionModel-pv5.0.so.1"
#20 vtkPVDataRepresentation::ProcessViewRequest(vtkInf ormationRequestKey*, vtkInformation*, vtkInformation*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVClientServerCoreRendering-pv5.0.so.1"
#21 vtkGeometryRepresentation::ProcessViewRequest(vtkI nformationRequestKey*, vtkInformation*, vtkInformation*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVClientServerCoreRendering-pv5.0.so.1"
#22 vtkGeometryRepresentationWithFaces::ProcessViewReq uest(vtkInformationRequestKey*, vtkInformation*, vtkInformation*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVClientServerCoreRendering-pv5.0.so.1"
#23 vtkPVView::CallProcessViewRequest(vtkInformationRe questKey*, vtkInformation*, vtkInformationVector*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVClientServerCoreRendering-pv5.0.so.1"
#24 vtkPVView::Update() in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVClientServerCoreRendering-pv5.0.so.1"
#25 vtkPVRenderView::Update() in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVClientServerCoreRendering-pv5.0.so.1"
#26 vtkPVRenderViewCommand(vtkClientServerInterpreter* , vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&, void*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerManagerApplication-pv5.0.so.1"
#27 vtkClientServerInterpreter::CallCommandFunction(ch ar const*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkClientServer-pv5.0.so.1"
#28 vtkClientServerInterpreter::ProcessCommandInvoke(v tkClientServerStream const&, int) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkClientServer-pv5.0.so.1"
#29 vtkClientServerInterpreter::ProcessOneMessage(vtkC lientServerStream const&, int) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkClientServer-pv5.0.so.1"
#30 vtkClientServerInterpreter::ProcessStream(vtkClien tServerStream const&) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkClientServer-pv5.0.so.1"
#31 vtkPVSessionCore::ExecuteStreamInternal(vtkClientS erverStream const&, bool) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerImplementationCore-pv5.0.so.1"
#32 vtkPVSessionCore::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerImplementationCore-pv5.0.so.1"
#33 vtkPVSessionBase::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerImplementationCore-pv5.0.so.1"
#34 vtkSMViewProxy::Update() in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerManagerRendering-pv5.0.so.1"
#35 vtkSMAnimationScene::TickInternal(double, double, double) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVAnimation-pv5.0.so.1"
#36 vtkAnimationCue::Tick(double, double, double) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkCommonCore-pv5.0.so.1"
#37 vtkAnimationPlayer::Play() in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVAnimation-pv5.0.so.1"
#38 vtkSMAnimationSceneCommand(vtkClientServerInterpre ter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&, void*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerManagerApplication-pv5.0.so.1"
#39 vtkClientServerInterpreter::CallCommandFunction(ch ar const*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkClientServer-pv5.0.so.1"
#40 vtkClientServerInterpreter::ProcessCommandInvoke(v tkClientServerStream const&, int) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkClientServer-pv5.0.so.1"
#41 vtkClientServerInterpreter::ProcessOneMessage(vtkC lientServerStream const&, int) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkClientServer-pv5.0.so.1"
#42 vtkClientServerInterpreter::ProcessStream(vtkClien tServerStream const&) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkClientServer-pv5.0.so.1"
#43 vtkSIProperty::ProcessMessage(vtkClientServerStrea m&) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerImplementationCore-pv5.0.so.1"
#44 vtkSIProperty::Push(paraview_protobuf::Message*, int) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerImplementationCore-pv5.0.so.1"
#45 vtkSIProxy::Push(paraview_protobuf::Message*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerImplementationCore-pv5.0.so.1"
#46 vtkPVSessionCore::PushStateInternal(paraview_proto buf::Message*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerImplementationCore-pv5.0.so.1"
#47 vtkPVSessionCore::PushState(paraview_protobuf::Mes sage*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerImplementationCore-pv5.0.so.1"
#48 vtkPVSessionBase::PushState(paraview_protobuf::Mes sage*) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerImplementationCore-pv5.0.so.1"
#49 vtkSMProxy::UpdateProperty(char const*, int) in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkPVServerManagerCore-pv5.0.so.1"
#50 pqVCRController:nPlay() in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/libvtkpqComponents-pv5.0.so.1"
#51 QMetaObject::activate(QObject*, QMetaObject const*, int, void**) in "/usr/lib/x86_64-linux-gnu/libQtCore.so.4"
#52 QAction::triggered(bool) in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#53 QAction::activate(QAction::ActionEvent) in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#54 ? in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#55 QAbstractButton::mouseReleaseEvent(QMouseEvent*) in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#56 QToolButton::mouseReleaseEvent(QMouseEvent*) in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#57 QWidget::event(QEvent*) in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#58 QApplicationPrivate::notify_helper(QObject*, QEvent*) in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#59 QApplication::notify(QObject*, QEvent*) in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#60 QCoreApplication::notifyInternal(QObject*, QEvent*) in "/usr/lib/x86_64-linux-gnu/libQtCore.so.4"
#61 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#62 ? in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#63 QApplication::x11ProcessEvent(_XEvent*) in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#64 ? in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#65 g_main_context_dispatch in "/lib/x86_64-linux-gnu/libglib-2.0.so.0"
#66 ? in "/lib/x86_64-linux-gnu/libglib-2.0.so.0"
#67 g_main_context_iteration in "/lib/x86_64-linux-gnu/libglib-2.0.so.0"
#68 QEventDispatcherGlib:rocessEvents(QFlags<QEventL oop::ProcessEventsFlag>) in "/usr/lib/x86_64-linux-gnu/libQtCore.so.4"
#69 ? in "/usr/lib/x86_64-linux-gnu/libQtGui.so.4"
#70 QEventLoop:rocessEvents(QFlags<QEventLoop::Proce ssEventsFlag>) in "/usr/lib/x86_64-linux-gnu/libQtCore.so.4"
#71 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsF lag>) in "/usr/lib/x86_64-linux-gnu/libQtCore.so.4"
#72 QCoreApplication::exec() in "/usr/lib/x86_64-linux-gnu/libQtCore.so.4"
#73 main in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/paraview"
#74 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#75 _start in "/home/eg634172/OpenFOAM/ThirdParty-v1606+/platforms/linux64Gcc/ParaView-5.0.1/lib/paraview-5.0/paraview"
Aborted (core dumped)
jpaolo is offline   Reply With Quote
dsmc openfoam dsmcfoam, paraview
